Where do people get their licenses from? I nearly got hilux'd this morning crossing the road. Farrk
Same place the Asian chick in a white Getz I saw on my way to work did. She turned left while indicating right... WTF!?!?
Morning Mangs
Yet to be pulled over, or even had a second look. Could be due to when and where i drive, but i think its mostly because the car's bog stock.
I don't get pulled over too often, do get looked at and followed a lot though.
Can some one give me a playing contract so I can go out and muck up and get kicked out of the club. Oh and still get paid out $1mil on leaving.
I will give you a $1/year contract to play the banjo. If you muck up and get kicked out of a club, termination payment will be $1.
Only catch is you have to be good at playing :thumbsup:
That's what she said
Sarp mangs. Sore throat is not so sore. Winrar!
Did the lube help?
fark missed a page :(
3rd last day today. Ducking out early however :)
I'm a big fan of ducking out early
hai guys :action-smiley-069:
so much ot do this week again....
McMarty, get the rom off the board yet?
hai Scottai. Nope, too hard. Did you buy the special tool thingo you were talking about?
Wheat Bix packets. Getting hilux'd can't be good.
*headsplode*
It comes with the car I'm guessing...
I've seen this all too often
Heading down to Jaycar this arvo. Or if you're not fussed on keeping the standard ROM, cut the legs. It will make it hella easy.
Throw in a piece of straw and overalls, and I'll start negotiations with the sister/wife.
hyuck hyuck
They don't. They spend all their money on $100,000 cars with custom plates and forget to buy driving lessons and indicators.
For sale, one set of BMW/Merc/Lexus indicators. Never used, current owner is stuck so far up their own ass that they think that everyone should give way to them automatically in all situations. Will swap for in car entertainment system so I can be even more distracted while running the kids to school.
  • Like 1
That's what she said.
Out of curiousity, link to said tool at Jaycar?
I couldn't care less about the the stock ROM. I did think of cutting the legs off, but my side cutters don't seem to be able to manage it :(. I might trying going in from the 'top' instead of the 'side', if that doesn't work I might just get the dremel out...
hyuck hyuck
A piece of straw I can maybe manage but overalls? C'mon man, I drive a 31... I can't afford overalls.
If I bought a $100,000 car, I'd want it to come with indicators. Just sayin...
I'll give you a fish tank and a mountain bike inner tube.
3.5 hrs
Impressive.
How do you blind an Asian?
Put a windscreen in front of her
No idea on the link. Just gonna roll down there and hope for the best....
I was trying to keep the ROM intact!! If you had of said not to worry, I would have cut the legs off it!
+1 cut legs off with dremel.
Or you can use a heat gun on the reverse side but you need to make sure you concentrate the heat onto the rom and not the surrounding chips
Furry muff... I'm just keen to see what sort of tool you have in mind...
Dow! Communications breakdown :(. If I give it back to you on tursday and tell you it's OK to cut the legs off, how soon can I have it back finished? :)
A supporting vote from the allmighty Dan? Sounds like a goer.
Not so keen on that technique... i'd cook something else for sure...
Annoying thing is I've desoldered heaps of ICs before just using my soldering iron and a solder sucker... this one's just being a right prick for some reason.
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
