How much are the Khumo's at Option 1?
Going from memory (it may be the other way round) in my sizes (215/45/17 and 235/45/17) it was something like:
595SS => F $110, R $120
KU31 => F $120, R $110
595RS-R => F $180, R $180 (on special)
Prices per tyre, plus fitting ($5-$15ea depending on if you want them balanced or not, and if they are on a car or loose wheels)
So in those sizes, the SSs and KU31s end up exactly the same price for a set of 4.
You want round phat black babys ? :O
Round phat black sticky babys :thumbsup:
Whilst the khumo might stick a tad better than the feddy SS just remember the SS will run rings around it in terms of mileage.
As an allrounder I still rate the feddy.
I'm not finding that. My last khumos lasted about a year. The SSs look like shagging out in about the same ballpark.
The SSs might have more meat left in the center when I'm done with them, but that doesn't help me if the edges are on belts :P
You're doin it wrong. :whistling:
There's nothing more I can do to reduce the camber wear on the rear. Its the nature of the datto-spec IRS. I have already spent a small fortune getting the base camber reduced as much as I can, but its still a tad over 2 degress, and it's still going to camber the f*ck up when it squats.
I could change the alignment on the fronts to make the tyres last better, but why bother when the rears wear out faster anyway? I like to keep the camber high enough to balance the rears, and I like a little toe out.
Ahem...cough cough.... GET A 33.
MWAHAHAHAHAHAHAHAHA
This could explain the stormtrooper walking down st pauls terrace with a suitcase this afternoon.
You guys should drive thongslappin' fords and holdens, you only need a good tyre on one side at the rear to get traction in the wet!
Epic night!
Ben (Homo) should get on here more often, then he would have something to do while waiting for his girlfriend to get really smashed at a work function
tears.
Very much so :(
The choice of who to but it from came down to two stores
Store A was slightly more expensive, but their website seemed more professional and they responded to emails quicker. They also guaranteed my phone would be shipped as part of their first batch of stock.
Store B was a bit cheaper, and they weren't sure how much stock they were getting in the first batch so couldn't guarantee they would have enough.
I went with Store A... Store B ended up with a truckload of stock, and worked through the public holiday and got almost all theirs shipped on tuesday. It seems most people who ordered from there's phones are in china already.
Store A has been dicking around, posting blog updates and emails on how hard their life is and how many orders they have to get through, and they hope to have them all shipped by the end of the week!
Backed the wrong horse... :(
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
