any one on here use openoffice on thier computers? Long story short I sent myseld work that I had done at home from openoffice and didnt save it as word format so I cant read them, normally this would be no problem as I would go home and resave them.....but sadly my computer dies this morning! So yeah if anyone has open office and a spare few minutes please please contact me so I dont lose a few days work!
This might work. Or you can email the file if you get stuck and I can convert and send back to you.
http://katana.oooninja.com/w/odf-converter-integrator/download
I don't have open office, but if you're going to lose a few days work and no one else can help you give me a yell and i'll just install it and do them for you.
Anyone else getting paid to drink coffee and eat custard tart right now? It's a good feeling :cool:
Earlier I was getting paid to eat pork tonkatsu. Right now I'm getting paid to drink bundy and cokes...
My actual work today has consisted of about 5 mins tapping away on my laptop.
:P
cheers mate, I have some one having a look at it now but if that yeilds no results I will give you a shout tomorrow!
:P
You win that one.
:P
Nice score! Was the five minutes of tapping to make your post about your day? Because that would be awesome.
New phone is camping ~100km from heathrow, waiting for the airport to re-open. Hopefully will be on a direct flight to brisbane by the end of today :)
Aloha mutherbishes...
So I turned up to BNR just after 9pm, to find.....wait for it....... no one.
WEAK!
Terrorist, McRae, Two-Bob, and I were all there. McRae left probably about 8pm to go do assignments, the rest of us bailed probably about 8:45pm. I was almost home when I got your message.
Colin said to tell you something... but I forgot what it was now.
hey Martin! I cant get any of this shiz to work regarding opening these documents, would I be able to email them to you?
I farking hate computers....and my inability to use them right.
Doing my timing belt and water pump tonight/tomorrow. Fingers crossed for no munched valves :)
Good luck! Did it snap? :(
Thanks kind sir, I owe you beer or icecream or somthing!
No worries at all! The thought of someone losing that much work due to a file type incompatibility is offensive.
If only our IT people felt the same way!
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
