I will try to attend
I no longer say I will, because my track record of late has been farking atrocious
:domokun: Bad Big sexy, bad...
I enjoyed your videos Mr Smith
T-bomb, welcome back!
Just lusting you, same old, same old. In for this Lakeside drive/steak!
It happens. Good stuff on the Lakeside dealeo.
Morning Mangs,
Hump Day :(
I know. I gotta go to Toowoomba.
I've been knocked off the top of the lowball club lakeside leaderboard with a 60.81 :(
To be fair though, he was driving a stripped out 344rwkw track only monster...
All i'm hearing is excuses boy!
I will ravage you
Fixed it for you :thumbsup:
On other notes, I'm in discussions with Stao about custom building up an new uber turbro for teh Telstar. :pirate:
I will avenge you
*APPROVED*
That's what she said.
welcome back!
*APPROVED*
So uber turbo has been paid for and will be built this week. 350hp+ atw in a sub 1100kg car.... Bring it!
that sounds like a weapon. what rubber is on said beast?
Bald bits atm.
I'll be slapping on some KU36's I think, as I need tyres. They're stupid cheap and they'll do until I can afford to put some real rubber under it, ala AO48's.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
