Any mangs want some furniture? Gf is moving to nsw and is selling alot of the furniture.
hmmm. i am currently sleeping on a couch and freezing to death each night because i have no blanket. what is up for grabs?
Fridge?
Have a fridge/freezer combo. 100 bucks, works etc
Edit: full list of stuff -
Basically there's 2 matching outdoor white couches, 2 florally green 2 seater couches, one 3 seater couch would suit outdoors as it's not too appealing, chuck a sheet on she'll be right.
If you want you can come around and have a look at what you want. Alot of the stuff was all sort of bought off friends parents etc as first house sorta stuff. It's not worth a lot but I figure its better than taking perfectly good sitting devices to the tip.
Edited by hylian
Sad sad state of affairs when this is in the driveway instead of my 32
Did you do some skidz!!?
Any luck on the wheel front?
i found some 350z wheels for 500 that been painted black.
Thought I could navigate this house in the dark... nope hit a corner and now my head is bleeding. Should I stay awake or just fall asleep and hope for the best confused.gif
I did a similar thing last week, smashed my shins into the coffee table. Got a lovely cut on one leg an a heamatoma on my other leg.
Quick question Chris,
My airbag light is on and no horn. i know it is the clock spring is broken, do you/can you fix this?
If your airbag light is on, start with IGN off, turn IGN to full on (but don't start) and press the door switch FULLY in and out 20 times within 10 seconds. That should reset the Airbag codes.
If the light comes back on then you have a permanent fault. The light comes on if you play with any of the sensors at the front or steering, regardless of faults
Harden up. I would have taken the wall down
Want a tissue? Or a coffee to go with that table?
When I bought my 34 the airbag light was on. Talked the guy down in price because of the air bag fault/possible clock spring issues. As soon as I took possession of it I tried resetting the air bag codes and boom, no more fault ;)
Coffee would be lovely. Can you also get me some fresh waffles and berry's and deliver them all to my bed so I don't have to get up yet?
that looks familiar
I offered him mine to use. I have no use for them.
your bit will take me a couple of days to do. can you shoot me your phone number please.
Waiting to hear back on some stuff. Daresay it'll be on the hoist again tonight :(
Combo did one accident skid. But nothing special.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
