28th sounds good for german food
Friday is turning out slightly better than expected. Wife is going up to Bundy with the kids and her parents this evening, whereas I will be driving out there tomorrow morning. Leaves me home to have a few drinks, watch football and get a solid night of sleep in. Win win win
Not hopefully broncos win .
hey guys sorry for the late reply been kinda busy with work and all haha.
do you guys meet on other nights other than thursday?? coz i work late thursday nights its not often i get a thursday night off. i had last thursday night off coz i was on holidays so i went to check out harrys diner.
That's almost as awesome a use of your time as punching yourself in the balls. Less enjoyable though.
Because Harry's Dinner is for Dyno Queen Dickheads and Auto Salon f**kbags.
So a guy who likes to make a powerful engine and put it on a dyno is a dickhead?
And someone who likes to maintain and make their car look the best possible way in their mind is a f**kbag?
Harrys is just a place for people with a car passion to hang out, I dont mind it, head there every few weeks to meet up with mates and talk shit, good fun kiss.gif
im with twocents, wats wrong building a car for the dyno or building a show car??
these ppl put a lot of time effort and money into building these cars. now im like any one with my own personal taste towards wat i like and dont like but even if i dont like it ((kingswoods for exampe and there was a neat one there the other week) i can still appreciate the work that goes into it.
If you're only going to put it on a dyno, then just build an engine. Not a car.
And if you're going to take a perfectly functionak car to make something completely impractical for the streets, changing/ruining the original design to the point of stupidity. Adding colors and chrome, TVs and full sick subs. Then be an interior decorator.
And if you're going to take a perfectly functionak car to make something completely impractiical for the streets, changing/ruining the original design to the point of stupidity. Adding colors and chrome, TVs and full sick subs. Then be an interior decorator.
Lol. i kinda agree with you. The people who build cars that they dont drive but trailer to shows i dont understand. i would want to drive it all the time. But people love to stand out and if they want to then you take the good with the bad. Some love what you have done to your car, some hate it. But its your money.
I dont see the point if modifying a car past what they class as legal
Yep, the only cars that should be taken on trailers are track cars, pre delivery cars and broken down cars.
Sarp mangs. Pretty successful weekend so far I started to do an epic detail on my car. Only finished claying the car so far but it's looking a lot better now. Has taken about 9 hours so far to get it ready for polishing. Shouldn't leave it so long in between details lol. And I definitely need to wax it more often to stop all the paint getting shit embedded in it.
Now I'm cooking a lamb roast like a baws.
my dads not a phone??
yeah man, its alot of fun, havent done mine for about a year now, and polish has been more than 6 months...not looking forward to the elbows full of grease that will be involved.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
