how much killer wasps does a supercharged bug motor make?
It varies a lot. Depends on how much you change the compression & timing and what charger/inlet/exhaust etc. Seen a couple close to the 150HP mark though.
Edited by Isola
All of which (especially the jetski) are water cooled? :P
arhhh yes, i now see your point... very true...
although im not sure about the Lexus, when you pop the hood all i see is a massive plastic cover...
so who knows whats going on under there, probably a big Japanese mouse on a wheel...?
also, you didn't tell me you were paying :P
also, there are laws that prevent that engine fitting.
Now you're just getting carried away :P
slight difference in air temperature/volume/density that cools that one :P
its a 41L just a lazy 2500 cubes lol
that will fit yeah?
That's bigger than the car!
The combined bore sizes are bigger than the length of the car ffs!
So? The point is that 150HP is not enough. And being air cooled is no excuse :P
Isn't that the one that caused most of the b29's to crash and explode in flames?
Probably. They should have used a Merlin.
It's plenty enough for a car and engine that size.
You wanna buy me a Porsche engine and pay for the conversion and mod plating, be my guest. Otherwise, direct bolt in FTW :P
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
