What needs to be done?
HT setup is now working like a boss
well..... i got an intercooler and a bunch of random pipes off Joe (guy in the burgundy R33 at the meeting on thursday night). from what i can see there is a pretty well full set of piping there.
I'm straightening out the bent fins in the front of the cooler, fitting it all. then painting the whole lot satin black with black silicone fittings to blend it all in under the bonnet :) so basically everything, and painting :rolleyes:
Morning Mangs,
Double RDO this week. Another death in the industry yesterday. :( Union will be looking for an even shorter week now.
Morning Mangs,
Cup bet placed. Going on my theory that the favourite never wins, I didn't put anything on Americain
Sounds too much like hard work :P
Morning Mangs,
Going to be weird walking past that building at uni now.
Morning Mangs,
Except for when Mkaybe Diva was a favorite 2 years in a row and took them both home :P but she is a pretty special case.
betting is fine at work. Their firewall is terrible/non existant. Boxed 6 horses for the trifecta. Hopefully it comes off.
Exception that proves the rule :P. Won't happen again for decades ;)
Mourayan was scratched! What is this sh*t? Might box up a trifecta to spend that money....
Or a way to lose it :nyaanyaa:
I cannot lose. It is unpossible.
The race that bankrupts the nation.
An assortment of incompetent politicians have already done that.
i wonder what will get more coverage today,
The Cup or the RBA decision
Cup, hands down.
A way to win enough money to buy a sim cockpit?
apparently normal race meets are far easier to win on than the cup! Most of the hardcore punters I know wont go near the cup.
The 31 boys at tafe bite real well when you ask them how's their pintara running :thumbsup:
Good form, keep it up :thumbsup:
Probably true
Probably true
Too many good horses apparently, at the smaller meets there is normally one or two horses that are head and shoulders above the rest. One of our mates is a horse trainer by trade, the bastard won $6500 one night while we were out drinking, even on a bad week he will make about $1000 out of betting because he knows all the trainers and horses. At least he pays for drinks when he is winning like that so I cant hate him too much!
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
