f**king housemate hasn't paid the bills AGAIN! Was thinking about moving out late March to early April when the lease was up, going to be a definite now. Try find something cheaper than the $260 a week I currently pay.
been there... done that... he no longer lives wih me. last i knew he was sleeping on the floor of someone elses house
Scrackin mangs?
So a month after the turbo install started it is finally finished, on my end anyway. Fitted the injectors and fuel pump today and did an oil change and flushed the radiator.
Only problem we had was one of the RB20 AFMs that I've got is a dud so it was being a prick at first wouldn't come on boost while driving just got fuel cut as soon as positive pressure was reached. So swapped it all out for the stock AFMs and it works fine now. I'm just going to get it tuned with the stock AFMs for now, can't be f**ked anymore I want the care back on the road lol.
Today = great success.
For the mangs who aren't on the 31 club. We got some new wheels for the ute.
Edited by Beelzebub89
Are you trying to make the ute the ugliest thing ever? Hellaflush fitment (or whatever the hell you want to call it) is just bad!
It's an R31 Ute...it will never be pretty. Front has a little too much poke atm but once the motor is in the guards will get some hammer love and all will be well.
lol looks very mad max
:thumbsup:
I like it, needs to be looking dirty boz
This man...he knows.
If its the one you got off me you're welcome to your money back :P
Whatchu talking about? She's gorgeous.
It's sport that isn't tennis so I'm keen. My housemate has been hogging the TV to watch more or less every game of the Australian open. Couldn't think of anything more dull to watch than tennis...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
