According to the traffic report, there's a police sting zone at the end of the centenary motorway.
Brilliant f**king idea.
So, who's coming on the cruise on Sunday?
Yerp trains farked today.
I got almost to work and then realised i'd forgotten my cricket gear. Had to turn around and go all the way back :(
Nope, all the washed out games means we're a sure thing for a semi final on Sunday. No cruise for me.
No one up for F1 weekend?
Who's going to go down for Skyline Nationals this year?
http://www.skylinenationals.com.au
Thinking of towing the wedge down, be keen for someone to share driving duties :)
Also, if anyone wants a free sticker, see me on Thursday night.
http://mycricket.cricket.com.au/common/pages/public/rv/draw.aspx?entityid=70&id=RVFIXTURE
No break, semi final this weekend and final the weekend after.
ehhh thats no good, I am gonna have to have a tune up this week, its been a while since we played!
I've at least had indoor, although despite a promising start to the year with the bat my last 2 efforts have been miserable failures :(
I did get a five wicket haul the other week though
That's what she said.
Hi John! :action-smiley-069:
you guys should come and play ice hockey with me @ acacia ridge... its gooood fun :thumbsup:
I'd have to grow my ranga beard to play ice hockey... and work wouldn't like that.
Morning mangs.
Who watched the India/Sri Lanka one day match last night?
How good!
I switched it on when i got home from indoor... was about the start of the bowling powerplay. Watched to the end, epic display! Was laughing hard watching ball after ball go to the boundary.
Wonder what odds you would have got on India winning with the bonus point at the change of innings?
That's where I started as well. They were at 210ish with ten overs to get the bonus point. I thought "if this was a T20 game they'd have to bat really well to get 110 in ten overs, don't think it can be done in one day cricket."
Boy was I wrong!
RE: Cricket - I received an email yesterday afternoon saying there were some free spots in the corporate cricket thing for sunday, includes dinner in the XI room!
Sadly, us mere contractors aren't worthy enough.
Edited by hylian
Boy was I wrong!
Kholi was a BAWS
I remember at the start of the test tour Tony Greig was going on "Who's this Kholi bloke and why is he playing instead of Rohit Sharma?". Now they all think he's the next Tendulka, lol.
In other news, infrastructure guys appear to have lost a server CPU. How does that happen?
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
