Mangs,
Long time.
+ 1 real boobs
+ 1 LSxs are for fags
+1 congrats on the new cars McFly and Carl
+1 that's what she said
Dan - half our boys diagnose engine rattles by revving the hell out of them too. We haven't had one seize yet though. I will lol when it happens.
Scrackin Mangs?
Very busy these days. We're running over programme on this project so bulk hours being done to reduce damages. Lame.
aloha Mc Bishes.
Meslow, I seeeeeeee yoooooooooouuuuuuuuu
lol, my split second of fame
that Golf R I was parked next was pretty nice
Numberplate was OOOK
Edited by PWND
The VG was considered one of the top ten engines in the world for a long time. I don't think the RB ever made the list.
Just saying...
Edit: Wait, I was wrong, that was the VQ not the VG. Please proceed with the VG engine out jokes.
Edited by -Boz-
