What happened to the job at Indooroopilly? Thought you were meant to be working on the renovations there.
Also, if you end up working on road projects I'm going to hold you personally responsible for every pothole I hit from now until eternity :P
We still have the job at Indro but looks like I'll be changing jobs. Got a job offer that is pretty much twice what I'm on now 14/5 roster with 2 days for flying.
Find any TIs?
+1
f**kin unlikely you'll ever be driving on these roads anyway
Easy enough to blame you any way
sweet news on the job offer!
so is that 14 on, 1 fly, 5 off, 1 fly?
Yeah that's pretty much how it goes. Director wants to have a meeting on Monday to discuss it but I'm pretty set on leaving. Will be putting in my resignation on Monday and then probably be starting out there in the 22nd of May or something like that. Need to hang around to get completion stuff sorted on this project.
Relevant
Mmmmmmm...
no parts to work on the leopard and too raining to work on the skyline
lazy sunday it is
I've got 2500 words to write and so far all I've done is watched Top Gear and Jimmy Carr...
After fitting the exhaust my coilpack misfire (or so i assume) seems worse. (although it only happened on track...not after i left lakeside)
there are plenty of threads on coilpacks etc on the forums, but i thought id come ask you guys personally. ive done the tape and silicone thing about 40k ago, and has lasted well since then. but now its time to replace. so my question is......(drum roll)
are yellow jackets, or the red coilpacks any good? or should i just go for the splitfires for a whole lot more folding cash? i wanna stay with standard location and fitment for the sake of keeping it neat underneath with minimal hassle (yeah i'm a bit slack at times)
I'm running yellow jackets, no complaints so far!
Straight fit and they are working like a charm.
Might be worth checking your voltage at the coil packs though, as my missing was caused by voltage drop in the wiring, fixed by a relay.
In other news, morning mangs, f*ck mondays. Did manage to get some work done on the leopard (re-fitted coil packs and replaced fuel lines), and the sun came out so I could at least swap the tyres back on the wedge.
Now definitely need leopard parts for more progress :(
cheers man, i heard you saying something like that the other day about the voltage drop. i can fix pretty much anything mechanical...but am entirely useless when it comes to electrics. So i really wouldnt know where to start. could prob find the right wires, but as for testing...thats where i get lost.
yellow jackets might be the go, my old coils have done 40k with the tape job done and that lasted a while (might even have another look)
in air I am told :)
wet morning is wet. bludging net access off mcd wifi.
martin, should have a number for you today. hoping to get the 31 on a hoist today at some point as well.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
