they'll get a sponsor no problem, the team is a good team always up the pointy end so good advertising for the right price.
When Betta Electrical went belly up it only took a couple weeks to get vodafailure onboard, my guess is they already knew so won't be short sponsorship next season
so where would you guys suggest buying coilpacks from?
best ive found so far for a series 2 is $440 del for yellow jackets.
and splitfires $575 del.
for the extra 135...should i just go splitfires?
well nothing that ive heard...just splitfires are alot more tried and tested and proven, i guess only because they've been around longer.
having said that...i do have a mixed opinion of splitfire anyways. my bug has splitfire plugs (about8 yrs old now...and the only performance thing available at the time), which work great. but my splitfire tacho...also in the bug.....leaves alot to be desired (VDO should have been my choice here)
lol.
for peace of mind?.... :domokun:
I have ordered the yellow jackets from performance-wise. $410 express posted! should have them in for next weekends happyness of lappyness.
just spent 2 hours fitting in this "reco'd" brake master cylinder, bled it up only to find when i tested it the thing still leaks out the rear seal
unless you have no other choice....never reco a brake cylinder. (is what ive learnt over time) and the kits are generally almost as much as the whole new part. :)
yellow jackets arrived today. epic delivery time from Performance-Wise!!
mmm poast.
day after origin...i wasnt heading out tonight.
on a related topic, coil packs are in in record time! 1hour between turning the car off when i got home, to firing it up for a test run. :woot: (engines are quite warm for a while after turning the car off...)
they work great, cant wait to hit lakeside on Sunday
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
