all good. just sorted it. $100
yeah, old plates are still around. Currently one is sitting on the bike, but will probably get it back on the car, once it's running.
depending on finances, could be a while before it's on the road.....
Ok, picking up the rolling shell Thursday. Anybody with towing connections, let a brother know. Caboolture to Bellbowrie
I saw you post this on Facebook today lol
It was just near Chermside, but he towed it up there to keep at a friends. Wish I had called him earlier.....
He's a member on here.
Picking up next weekend now, as I can't get up there in time this arvo, and he'll be away till next week.
  • 4 months later...
  • 4 months later...
BUMPAROOO
I live in Auchenflower and have been very quiet on SAU in recent years.
Wondering if there are normally any weekend drives over Mt Glorious/Nebo for example?
I also ride and compared to the bike scene, the car scene seems to be very quiet?? You can always bet on a squirt up the hills on a weekend morning.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
