Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
Morning Mangs,
Site managers first day on holidays so I've spent the first 2 hours photoshopping random pictures for the site foreman lol. I should probably do some work though...maybe.
Morning Fellows! Hows it all going? Hopefully chucking the new brakes on my car on Saturday or Sunday, been ages since i have done any spanner work. Looking forward to it! Even if it is an easy job lol
Mangs,
Sitting at Motor One waiting for them to tint a craptiva. It's a good break from how busy it's been today + the heat :thumbsup:
*waves out the window at Dan*
Well dont we have a cushy job :rolleyes:
I do
I rekon i do to as am at work and bored so reading SAU. And my boss doesnt give a f today either so great day.
So... anyone want to buy a new car :whistling:
Mangs
Playing COD
Busy day, so will get back to it.
As you were
WTF I pressurised my intake system again... all my piping seems fine. It seems like there's an air leak somewhere around the rear of the motor, on the turbo side, kind of around the back corner of the rocker cover. One of the screws there was half a turn loose so tightened that but realllllllly doubt that was the problem. I already packed up the compressor etc so I didn't check again but I doubt it did anything.
What other pipes run around the back of the motor that carry pressurised intake air??
Anyone have any opinions on this?
Yes I do
But I am looking at a BMW 535i, So if you have one of those it would be great!
Yes I do
well if you look at the cars i sell front on and they are in silhoutte then we would be close
It's F*cked.
:P
Sorry, pretty hard to have a guess at what's wrong over the interwebs.
The only hose that carries air towards the back of the motor should be the feed for the idle control motor... can't remember if this is pressurised or not, I think it comes of the J pipe though so I would guess yes.
My money is still on exhaust leak before the turbo or wastegate stuck open.
Andy,
Our garage is empty enough now, if you want to start to use your garage for your car instead of storage.
Andy,
Cool, You around on saturday? Might get it towed then? PM me your adress and I will start ringing towies!
I thought wastegate stuck open as well. But then again I don't have a big idea of this sorta thing.
Just realised new sau layout is mobile friendly. Yay.
Tappet cover gaskets will leak like a bitch when thos screws get loose (Which they always are) Tighten all the screws and go from there. My R33 has lots of leaks from that area and when i fixed it all up the car was much better behaved, Of course your gasket may be rooted too but try tightening everything first
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
