Inner West Crew Whoretown (toowong/st Lucia/kenmore/indooroopilly And Sometimes Sunnybank?)
good to see tas you opening a trading acc with mobil, dad said some guy was going to ring you.
at least now your rockin the good shit like milmaks lol. just happen to be there main sponsor.
after seem sealing / 2nd coat.
got some orange peel but what do u expect, i neva done it before,
colin need your epic detailing skills to buff it out. :D
Yachts normally go for more than that, probably needs some work for it to be sea worthy....
as for 31 coilovers, JIC did actually make coilovers for 31's. Also plenty of Datsun shops make coilovers from R31 struts.......
but yer, i'd still love a 1970 C10 GTR skyline.
If it was sold I wonder how much was the selling price...
for that price... You can get a VERY nice M-Spec/V-Spec2 Nur... or maybe top up a lil and get a Z-tune or a 35gtr...
Technically, the stock suspension ARE coilovers :) just not height adjustable. As you well know, those JIC ones are 20 years old and shit.
Making height adjustable coilovers from the standard strut, yeah it works, but I consider that 'custom'. Also, you still need decent inserts then to run in them, and you lose wheel clearance.
I know where there is a shell of a white FD sitting, its been there for 2 years now, sitting right next to the road nothing stopping it goin missing either
rotarys are easy, boost in apex out, rebuild and repeat. haha
anyone got a clue how to TIG weld here?
get me a tig and ill teach myself, i know the basic principles.
ps: marto that vid is f**king hilariousness TRACTOOOOR !!!
and u learn something new everyday: cows go moo when the poo LAWL
Yea I finished reading the whole thing but basically the main thing I've learnt is 1.3l twin rotary is actually 3.9l in displacement. And you cant really compare piston and rotary.
yer rotarys arent as bad as they are made out to be, boost them hard and not build them right and they will give you nothing but trouble, a properly built one with moderate levels of boost last ok. Like 1000Hp from a 1.3 litre engine is crazy and no doubt will give you issues, same as trying to pump that level of power from a RB engine.
Yer dave im teaching myself how to MIG weld, funny thing is my missus can weld better than me :) i will get a TIG once i learn the mig.
martin, get the falcoon and a trailer and i will show you where it is :P
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
