  • Replies 207
SKYBEE - your lucky to have black. any colour will suit it.
BLUE RED GREEN PURPLE AQUA.
just click the link above to see a picture of the blue kit.
if anyone is interested please feel free to email me at
[email protected]
and i will do my best to help you out.
  • 4 weeks later...
Never thought I'd say it, but i'm interested too.
Could you please shoot over any more pics and info you might have. I think Blue ones will go best on my silver R33
Thanks...
[email protected]
i know the bloke that owns the white skyline.
hes very happy with his neons.
melv, did you used to own that white commodore vt or somthing with trippy looking rear lights?
Hey champ,
yeh i used to own the White VT (02DEF)
then i owned a White VXSS (SIR VX)
and now i own a White R33 GTR ( havent got plates yet )
will have to meet up with u champ i rember u from the BWCC FORUM etc.
i never thought ide add neos either but hell
im sold!
i live in brisbane, so once i get new wheels for my baby ill be driving to the goldcoast to come see you!!
now i just need to decide.. Blue or Red
ahhh!
silver skyline hmmm
hehe blue it is
so whats the fitting like?
cause im getting new bodykit fitted and some other little things done over the next few weeks.
Whats do you think would be sufficient for an r33 gtst, do i want 4ft ones for front and back and 5-6ft for the sides? If im going to do it i mite aswell do it right :)
how much would that be?
1.2m sides
1m front
80cm rear (coz of your exhaust)
that kit will be $200 - $220 inc courier.
fitting is very basic. drill two holes and cable tie them up to the side skirts or if u want it done right, drill into the bottom lip under the side of your car hold the neon on the inside of lip and cable tie it into place easy as that really !!
hey mate,
u get a transformer that u can mount in your engine bay or hide it somewere and from that u have 4 wires
two thin which are black and red red goes to your switch in the cabin and the black to a negitive
there are also TWO fat cables both a positve and it needs to run in a circle type circt under the car.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
