  • Replies 56
r8 will do a high 13s so u gotta do better then that to beat him.. and for ur car costing $14,500 and his costing $38,000
u can put a 13bt in a old 1970s corolla for under 8k, and it'd rape a r33 as well as a r8 ..... has nothign to do with money.. u cant compare the 2 cars they r so diffrent.. marketed for diffrent groups in society...
well, i can tell you that the cv8 monaro at about 230kw i think gets flogged by an R33.
My mates R33 had turbo back exhaust and pod filter and still easily had the race... now he has an EVC with 12psi and it wouldnt even come close.
i reckon u should run on about 10psi first and see if you beat him... then up it to about 13psi and really flog him... if he still isnt crying go for a run at 15psi and really kick him :(
Grey Skys - that's right. If your a good driver you'll do better times with the traction control off.
Apparently the best acceleration occurs with about 10% slip (we're talking dry road/good conditions). But more than this and the acceleration drops off very fast - it's hard to stay on/around this amount of slip.
J
Yeah traction control from my understanding is just the car telling u "no" to the accelerator, or applying the brakes (and if it's advanced enough, only the specific brakes) really quickly on/off to stop the wheels spinning. So prob not the best thing.
And zdenko, there is no point saying u can by a 1970's bomb and just put a rotary in, cos that isn't what the car came with in the first place! It's 1 complete factory car, vs another factory car. Saying u can buy this shell car and drop some complete foreign engine into it, doesn't have much to do with a R33 vs an R8.
cheers.
The Wheels and Motor timing equipment is SLOW if anything. Like what Rob said, they're also carrying a full tank of fuel and a passenger plus all the Correvit/satalite gear.]
From my own experience, High 13s if he can drive, mid 14s if he can't. Any slower than that and there's something wrong.
When will the "My R33 against his Commonwhore" end ?
Anyway, I'd say you'd give him a run for his money for sure, even if he wins by 0.1sec it still proves your car is better....
He paid $35g and you paid $14k, and you car is 10years old!
It will be at Calder park one friday night.... dont know exacly when we have to organise that shit... and scrape together the $55 competitor fee, remember i just got my car and am still trying to afford insurance, and he just spent $35g so he will never have spare cash again :D anyone want to give me $10,000 so i can make my car really fast...... words like hi-flow, Power FC, and front mount intercooler come to mind..... money is my only obstacle..
im with the Skyline on this one,
Depends fully on the way you drive the car too,
But with good launch,
Personally i think youll pull away at the start quite comfortably then when the R8 heavy monster gets moving it will be real close.
Be sure you to post results, cant build up thread like this then not conclude! :D
V8's have most of their grunt down low. If they can't beat you off the line then you should be able to pull away as the revs climb. I've done it with a Commodore in the street and the GTR's and Sierras did it to the Commodores at Bathurst on Conrod straight.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
