Hi Jules, The guy to go and see it Steve Maitland, Maitland fabricators, makes the majority of cages for all the waneroo race cars. Cost will depend on how many points the cage is, but it's damn expensive:(
If you want to go cheap then you can just buy a bolt in cage.
Jules , the CAMS and ANDRA specs are different and one cage will not be legal for the other unless the CAMS one is engineered.
pwptpf is right , Steve Maitland is good , on time and on budget.
Other places to try are Ballistic Racecraft ( Wangara I think ) and Guru Welding ( Carlisle )
Mark Bourne who is operating out at Fastlane in Wangara is another one.
Both Mark and Steve have done cages for me and Louie ( Guru's ) have done plenty for guys I know in Rallying
Cheers
Ken
Originally posted by Steve-SST
Trust me Steve Maitland is the guy but wait till he finishes my GTiR
OK.
He had better be doing Adam Smits WRX atm or there is gonna be trouble...:P
Cheers
Ken
He is Ken i looked at it today, then his on holiday then his doin my thing.
Holidays , HOLIDAYS !!:P
What does he think this is , the bloody government?
Doesn't he know that private enterprise does not take holidays.hehe
Cheers
Ken
Originally posted by PSIKO
when's he taking a holiday Steve, and also finishing your gtir?  Would want it done sorta quickly so may have to grab one of the other guys to do it, no drama
will go see those guys next week, cheers Ken
Aside from maitland, Kim ledger at LF has just employed Brad stacey who's also pretty ace at cages..
Paul a few factors make it legal, material is the big one, CDS or cold drawn seemless steel is the easiest option to make a cage with, as chrome moly and ally need to be inspected and signed off by an engineer..
other than that the cams rule book describes in detail different cage designs and whats legal, you can add extra bar work in to your desire, but it must comform to the regs regarding clearances and the like..
as a side note a lot of the jap bolt in cages are not legal, and cusco are the only brand i can think of that make legal cages, but not all of there cage models are..
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
