Ok , so these are the final set of try and fit wheels from my car which i dont look to need. They are white, very good condition,
Fronts are 17 x 8.5 +30 , perfect for an R32 GTSt and fine for all other things Nissan
Rears are 17 x 9 +28, again a good fit
I am binning these as i was able to get 9" +28 working on the front and 9.5 +35s on the rear so finally all sorted for wheels that fit good rubber and clear brakes.
Can get pics but they are what they are, sadly they are in gay GSTt offset so dont look near as good as GTR offsets but they are way light, good offsets for GTSt and clear big brakes.
No tyres, asking $2100 + delivery
https://www.sau.com.au/forums/topic/261867-17-te37s-white/
  • 4 weeks later...
I'm the shit bloke he has been waiting on for pics. They are in great condition. If you would like to inspect them in Melbourne PM roy or myself.
LOL, all good, the guy that seemed keen PM'd me saying he was no longer interested :blink:
As for tyres sizes, i guess for the 8.5" ou can go anywhere between 215 and 245
For the 9" you can go 235 to 255, maybe 265 if you dont mind them balooning out a little
https://www.sau.com.au/forums/topic/261867-17-te37s-white/#findComment-4540404
The fronts have a few chips on them. The rears have some scrapes but the rims have been resprayed with new Volk stickers. Like i originally posted, i purchased a set of TE37s which were 8.5" fronts and 9.5" rears. I grabbed a set of 9" all round so that i could try and make use of the 9" fronts on my original set replacing the 8.5". LOL still with me? Thats why this particular set of rims are the left overs comprising the spare 9" pair which can be used as the rears and the replaced 8.5" from the fronts.
I have no idea of a postage price to Adelaide, depending on your offer i will be happy with $100 for shipping. If your offer is borderline of what i can accept then i will hav to get a quote for your postcode
https://www.sau.com.au/forums/topic/261867-17-te37s-white/#findComment-4569661
Hey Bris,
what kind of weight are TE37s? Might be looking for some affordable track rims when i finally return to victoria. (if you still got them in June?)
Will also kind of depend if the offsets will work magic on a 33 gtst. Haven't got my car up here in sydney to visualize.
Cheers
Cam
https://www.sau.com.au/forums/topic/261867-17-te37s-white/#findComment-4588122
Well if they go to somebody i know i will do a better price :) The rears are effectively R33 GTR rims for width and offset, so if you can find an R33 GTS25T running GTr wheels that will give you an idea for offsets.
The fronts are only 8.5" so will sit about 6mm further in from the guard, (more clearance) so again will give you an idea of guard clearance.
I really need to get rid of these before June. But if i still have them then you are welcome to throw your tyres on and see if you are happy with them
https://www.sau.com.au/forums/topic/261867-17-te37s-white/#findComment-4592109
Oh man, i cant answer that. I am OS, a friend is babysitting my place for me and catn ask him to throw on the scales asi dont even have scales at home.
They are generally seen as about the lightest forged wheels going, along with CE28s. So i would expect them to weigh about what my old Wed TC05 and Nismo LM gT4s weighed which is between 6.5 and 7.5 kgs each.
https://www.sau.com.au/forums/topic/261867-17-te37s-white/#findComment-4593093
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
