hey hows it going everyone.
earlier tonight i picked myself up a vg30det turbo (45v4) ceramic ball bearing turbo.
ive just been reading up on this forum and it seems to me like everybody on here hates them?
im just after some realistic figures here of what power gains im looking to make on my rb20det and why the rb25 turbo is better.
i know it has better midrange, but what about up top? and when comparing final power figures which is the better option?
at the moment my car has:
GFB bleed valve
2.5" straight through exhuast (also how much more power would i be looking at if i ran a 3"?)
FMIC
2 core Alloy radiator
Pod filter
4puk heavy duty clutch
mint compression and coils
Iridium plugs
RB25det fuel pump
New fuel filter
I am currently running 11psi on the standard turbo, i would probably look at running 13-14psi on the vg turbo
Sorry one more question. my standard blow of valve has been unplumbed. are there any consequences to this?
Thanks alot for any info and/or help provided.
-Jonny
https://www.sau.com.au/forums/topic/261871-vg30-turbo/
  • 5 weeks later...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
