  • Replies 141
Updatez ....
L8RSXY
FOXV35
MJAY
OGZ007
V35DRIVER
SETHAIYAR
BLISTC
V35MATT
TOKYO JEFF
WINZ
POPEYE
RUSSKY
Scathing
SilverV
Dftreaper
lee98b
tomorrow i'll post up the exact level that we'll be meeting up guys ...
Cheerz
* K *
Hey guys have we thought about if there will be football on that night? The stadium is around the corner and its a nightmare to park when the footy is on.
yeah good thinking t88.... can someone find out....
i will make sure one of the photographers from the magazines come out.....anyone see the v35 meet we did last year, its a 4 page feature in HPI??? if not go get it... issue 107 on sale now...
Ok guys checked Sydney football stadiums website:
NRL: Sydney Roosters v Knights
Saturday, 16 May 2009
5:30pm - Sydney Football Stadium
Any solutions? Kingsford Maccas lol??
Hmmmmm how about Bada Bing strip club kingscross??
P.S. Bought the latest issue of performance imports and saw the cruise nice pics, very impressed.
There are a few nice photo's of yours Kareem have you seen them
Edited by T88turbo
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
