have had a slight miss for quite some time, but it has only been evident inconsistently at idle and hot whilst driving.
decided to get off my ass and change the plugs which i had not done so since getting the car and it has done over 15,000kms since then. while i was there i did an oil/oil filter change as well.
so, changed to NGK copper heat range 6 and the problem got worse? what i seem to think is that the plugs have improved spark and this just exentuates the same problem rather than making it worse.
So i then reset the ECU and cleaned the AFM and a little bit better but still noticeably there.
what do you guys think?
i was thinking:
- clogged injector
- stuffed coil
is it worth chucking a bottle of injector cleaner in? or is that stuff bad?
please help!
Waz.
https://www.sau.com.au/forums/topic/26193-missing-problem-plz-help/
my car was missing, I took it in for a full service and for 'em to check this problem, they said one of my coil packs was not working properly and the timing was a bit off.
They fixed the timing, and no more missing!
maybe that might be the go for you...
0.8mm
i just checked the timing the other day and set it to 20deg so i doubt that would be hte problem
its very inconsistent. ie sometimes it will happen more and sometimes less. and i can't hear of feel anything when accelerating. that's why i'm thinking injectors.
oh, and at cold start the problem is pretty much non-existant only when the car warms up.
HELP!
Injectors can be cleaned at an EFI specialist, they clean them with a ultra-sonic method. (For more info on servicing injectors http://www.cruzinperformance.com/injsteps.html)
Although injector cleaner (fuel tank use) might show improvement its not as thorough as the ultra sonic method.
I had mine cleaned and tested and it turns out one even after cleaning only did 90mls to the 100mls. I changed the injector and fixed mine from missing at idle and cruisin.
MEGA
    • I've replaced the front brakes of my NA to 324 brembos and 350z calipers: i'm going for 225/40-18 up front and 245/35-18 in the back. I have Rays 7.5*19 ET35(225/35) in the front with 5mm spacers otherwise the calipers "lock up/ won't rotate". When i use the calculator i come up with 8*18 ET30 for 225/40...... but not sure i get problems with the calipers. Anyone riding around with 18 inch. that can confirm "that it'll fit"? In the back it's 7.5*9 ET30 (245/30) with the 5mm spacers, but there is no problem with the standard small brakes, so i want to take 8.5*18 ET25 (245/35).
    • Lol.. but then.. always come back to a JDM..
    • Glad to hear. If possible, get your tuner to check air's to make sure everything is still where it should be.
    • The problem with FB/Insta/Reddit etc comments relating to cars is simple. You get to ask a question once, and get one round of replies. For things that can actually be answered in a few lines of text, once, it's fine. After 6 hours, your original question is lost to the void. There are no follow ups, additional questions, anything. No project car is ever such a simple list of questions to ask. You need discussion.
    • Welcome.  Here's what I have noticed about forum vs FB..... FB; seems to be wallet racing, and the same few questions asked over and over. There *may* be some groups that are closer knit, but most have changed for the worse. SAU; unfortunately, no longer in its glory days. But....genuine people with similar interests. Not all about how much you spent and saying you dont have enough power. Sooooooo much knowledge available. Have personally seen people post up about literally topics I made myself, asking on FB like no one has done it before. Most has been done, and most of that is here.   If you ever feel like just general chatting theres the wasteland.  Other interests are also generally covered in other areas of the forum. Hope you enjoy hanging around. We would love to have you.   P.s. nice 32 😀
