Yeah, I'm at it again :P
Whilst I was underneath the M35 I also noticed what I thought was a Nismo muffler, actually turns out to be a Nissan Sports Muffler.
The product code on the back left side of it states B0100-AQ825.
I've taken some pictures, it's a nice sounding muffler, was wondering if anyone had access to the specs for it.
https://www.sau.com.au/forums/topic/262000-nissan-sports-muffler/
MIKE - that's it for now, only the two items I'm curious about.
Ryan1600 - thanks :P
Yeah, I've goggled both car numbers and havn't found anything of relevance.
I suspect the "Nissan Sports Muffler" may actually be a Nismo product but doesn't have Nismo marked on it anywhere. It has a sound control switch and a box on the front of the muffler (near the rear tyre).
I need to get the car up on a hoist so I can have more of a poke around undernearth :(
I know a mechanic who may help me with this, it's too low to get under to have a poke :laugh:
zei20l - nice try man :P
I'm not looking to get rid of any of it atm, merely wondering how good it all is :)
I need to start the list of mod's, lol. who know's maybe I win the lottery soon.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
