Hi guys, long time reader here first time poster
I've got a r32 gts25 sedan that i've sold my 20det setup (284rwhp if anyone cares) to build a RB30det, so far i've got a garret truck turbo, similar size to 3540, rb30e bottom end and r32 25de head, gtr valve springs, oil pump collar, just buying up the bits as i see them basically
I've also aquired a set of 26dett pistons, I've tried searching and haven't found a definite answer to if i can use them or how much work is required? i have a set of 30e pistons to which i'll use if the 26's arent any good, basically what i'm asking is  a) how hard are the 26 pistons to fit, and b) is it worth it?
thanks in advance guys. I'm sure i'll have many more questions as the build progresses
Cheers :P
https://www.sau.com.au/forums/topic/262171-rb30-gtr-pistons/
Pretty sure you have to use RB30 pistons as their pin heights etc are to suit RB30 rods & crank..
cheers for the reply, so i cant use 30 rods with 26 pistons? i havent had a chance to measure anything up yet, was trying to avoid wasting my time if people already knew the answers haha
might have to take them into work and whip up some drawings to see if its a suitable option,
Not sure on the exact differences, I'm using RB30 spec forged pistons. You might find that with 26 pistons on 30 rods on a 30 crank that you could be smashing pistons into valves.. need an experienced RB builder to answer that :P
cheers guys, turns out one of them is poked anyway so ill prob just stick with the 30 pistons, on the subject of 30 pistons, i've got a set that i had ultrasonically cleaned, when they came back they had lots of pitting in the top of the piston, im assuming its just bad casting/ has anyone else had a set that were the same? i tried to take a pic but it wont pick up the detail- aka budget camera
That pitting is probably from detonation..
I was hoping that wasn't the case but had my suspicions, picking up another motor tomorrow hopefully the pistons in that one are better, first motor had a bent crank (god knows how) so i had to buy a whole new motor to get a new crank, what a mission just to get more power!
Bent cranks are quite common in i6 engines.. just make sure you get all your clearances checked and machine appropriately.
it had about 0.3 bend in it, decided to try another as its cheaper to get a new one than grind, bit of a gamble to but its a low k's engine so should be ok
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
