Is the current coppermix twin the same as the older g-max twin and is
the current coppermix twin like this...
My clutch has some rattle at idle at the lights. it slips fine when cold but when
hot becomes quite grabby -- so that I find it difficult to ease it into motion from a stop
without provoking drive-line shudder, to the extent the transmission (gear shift) will
visibly judder up and down.. in other words, when hot there is just no more
smooth slip available anymore. Just judder.. or fully "on"..
of course after you are moving, or you take off fairly smartly, all is good. The judder
is most difficult to avoid in fuel station forecourts, parking garages, etc. And only
when really hot. Eg, after 30 minutes of driving or more.
Edited by moneypit
https://www.sau.com.au/forums/topic/262244-judder-when-hot/
The new Coppermix is completely different to the older G-Max clutches. They are HUGELY smoother.
thanks, well, I guess I'll upgrade when it wears down too much.
I was told that almost all suitable clutches are like this, except for one expensive HKS model which doesn't rattle.
but it is good to know the current coppermix twin is better than the old g-max twins.
https://www.sau.com.au/forums/topic/262244-judder-when-hot/#findComment-4514767
yep the G Max in my car does the same thing, judder and carry on... I actually find I drive it better in bare feet as I can really feel the catch point!
I used the Coppermix single in my old car and it was a lovely clutch but didn't hold the power I needed it to... never used the twin but I'd definitely consider it for an upgrade when this one is gone, supposed to be much better than the old G Max... there is a review somewhere from one of the V35 boys who put the Coppermix twin in his car, mixed results there though
https://www.sau.com.au/forums/topic/262244-judder-when-hot/#findComment-4515617
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
