Hey guys i have for sale my set of sp1's
Brand new pair 18x11 -32 $1950
used pair 18x9.5 +22 $1150
buy the whole set $3000 firm already loosing $200 only had them 4 2weeks
also have a pair of brand new nexen 275/40r18 askin $240each or $440 4 the pair
contact pete, on 0407008651 will also swap wheels 4 17`s or 18`s with cash my way depends on wheels intrested in something with dish or some te37
with good offset.
located in blacktown area
  • 3 weeks later...
sorry mate... i put my rears on my front and they dont clear my calipers, so i'll just stick to the professors i already have :banana:
disregard pm :P
gl with sale
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
