I have a NISMO OIL CAP which I bought 2 of now my friend says can't afford to spend the money for the one I bought for him.
THE DESCRIPTION FROM THE MANUFACTURER........
It is Brand New in Box Billet T6061 Aluminum Bronze Oil Cap for Most Nissan Engines .We use a Special Anodizing Process in all Our Oil Caps for a Better and Long Lasting Finish . NISMO Emblem is made of 100% Real Carbon Fiber .
NOTE: This oil cap will Only Fit Nissan Engines With Screw In Style Oil Caps , Will not Fit Twist And Lock Style Oil Caps Please check your Stock Oil Cap before Ordering !!!
Selling below what it cost me $74.95 + $4.95 postage.
Just pm me if your interested or have any questions.
Thank you.
https://www.sau.com.au/forums/topic/262444-nismo-oil-cap/
Hey sky88 what's happening? I sent you payment already? Still no more reply from you since payment made?
I HAVE ALSO MADE PAYMENT FOR THIS CAP AND NO REPLY!!! SKY88 PLEASE CONTACT ME ASAP ON 0415963870
LEE
https://www.sau.com.au/forums/topic/262444-nismo-oil-cap/#findComment-4505542
Oh that's good to hear sky. Just would have been good to have known what you was doing earlier so we wouldn't have panic attacks...lol
I might have a friend interested in one also if you have any left by the weekend.
Cheers.
https://www.sau.com.au/forums/topic/262444-nismo-oil-cap/#findComment-4507673
I'll take one thanks, has anyone got theres yet? or this a scam after all?
Nope still nothing. Paid on 25/03/09 and not even a pm to say whats going on. Direct deposit doesnt take over a week.Seems to have time to say still 4 left i see. I recommend to others wait to see if anyone gets theres before giving away any money.
https://www.sau.com.au/forums/topic/262444-nismo-oil-cap/#findComment-4514206
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
