selling my R33 stage 21 bonnet...
its suits R33 series 1 or 1.5 ONLY
unless your fitting to a drift car where your not running head lights etc..
new unused unpainted & still in gel coat. the rear of the bonnet on the left has the corner tip
knocked off and is a easy fix, but it looks worse in the pic than it really is.
was only fitted once for trail, but ive gone a different direction and style, so
no longer needed..
p.s: yes you can lay a sheet of carbon fiber over it if you wanted to if you
after a carbon fiber look bonnet..
selling for $300 firm.. this is a very lite and well made bonnet
Edited by NGK
https://www.sau.com.au/forums/topic/262813-fs-stage-21-fiber-glass-bonnet/
  • 1 month later...
When you had it fitted temporarily was it a nice fit along the side of the front guards and around the headlights ... I have seen some that are really shocking and not worth even trying to make them fit, but if this one is decent then it might be worth having a look at and test fitting before possibly buying?
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
