Sunday April 12th, 2009
The first one of the year with opportunity to take some day pics of yr rides whilst enjoying and early dinner.
Meet: Chatswood Chase Car Park, Enter off Victoria Ave
Time: 4:00pm, Leave by 4:30pm
Destination: Palm Beach via Newport for Pizza.
Bring: CB's, a full tank of fuel and a GOOD attitude.
As always, don't do anything silly as we are on public roads and we do not want bad attention drawn to the group...
We are enthusiasts not hoons or a gang of ANY type out for a drive NOT a race!!!
Traffic will not be an issue because we will stick together and to the speed limit at ALL times.
If you decide to do the wrong thing.....YOU WILL BE REPORTED TO POLICE - this is NOT a joke.
Pizza Place:
Lucky's Pep's Pizza Bar
Shp2/ 303 Barrenjoey Rd Newport 2106 (02) 9979 1756
https://www.sau.com.au/forums/topic/262944-p-i-z-z-a-c-r-o-o-z/
  • Replies 88
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
