Hey everyone i have an r32 non turbo gts and for the past month i have been thinking do i want to keep it or do i want to sell it. If i keep it a want to put an r32 gtr rb26 twin turbo into it but not sure how much it would cost so im just wondering does anyone have any idea of how much it would cost to put an rb26 twin turbo engine into a r32 gts non turbo including everything that will need to be done eg. gearbox exhaust clutch etc. ?
Thanks for your help.
https://www.sau.com.au/forums/topic/263144-deciding-wheather-to-do-this/
i know it wont be the same as a gtr and it wont be awd thats not what im looking for i have recently put a new kit on it and sort of starting to fall in love with it again and dont dont to keep it or sell it so i said to myself if i kep it i will turn it into a project and put a rb26 in it.
I can hear the brakes crying already at the thought of this conversion... You will defenitley need much larger brakes. the suspension wont be right for the weight of the rb26 either.
Really, other then the fact that the chassis can support the engine, nothing else will be suitable and will need to be changed...
Edited by bnr#@
really not worthwhile unless you are super keen to get your hands dirty yourself. By the time you have gotten everything, paid someone to put it all in, found the 5-6 things that weren't right and bought the right ones, upgraded all the things that wont be up to pa (the brakes), decided you need a 5 stud conversion, etc etc. You will have been able to buy a turbo for 1/2 that and in 1/10th the amount of time. So yeah unless this is a process you want to experience.. don't :D.
and RB26 is just multiplying the problem more because you are talking about an engine that really wasn't designed for the application. An RB25 would be more sensible, but really.. just buy a gts-t. Enjoy that until something dies.. and then think about engine swaps imo.
At a rough guess. Paying someone to do it it, and get all the way up to the same car as a gts-t. 5K+?
Paying someone to put an RB25 in. 8K+?
Putting an RB26 in. Lots? :D
The worst problem you have is the gearbox. If you stick an RB25 in front of an RB20 gearbox it wont last long, but if you stick a hyped up RB26 in front of it, start praying :D
As the other guys have said, brakes, suspension, ecu, fuel pump, possibly drive shafts &/or diff, different intercooler, better clutch, & probably a few other things i havent thought of lol. I considered it myself, i reckon best option is an RB25 DET NEO. You can milk some decent power outta that beast & itll still be RWD, get an R33 box to put behind it too. Or the R34 unit, havent heard much about reliability or anything, but its the same as the R33 as far as ive heard, so bloody strong!!!
Keep me posted if you go ahead. That will give me some ideas to see if i wanna do it also.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
