My mate is setting aside a day for us to have pics of our cars taken!!... he will do the shoot for free but will charge $10 per edited and print ready photo that you desire.
He will Run the shoots over a couple of weekend (if need be)
Models will be available if you want that aswell!!
Details will be given once we see if there is enough interest
Regards
https://www.sau.com.au/forums/topic/263327-car-photoshoot-5th-april/
  • Replies 75
Regards
hehehe very enticing... pics of models available n how many? :D
ok guys i have a few models organised and 2-3 photographers... so i am going to start making a time schedule!! please tell me when you would like to go. once i confirm the amount of photographers and models more time slots will become available.
10:00 - Setup
10:15 - Brendan
10:30 - Donovan
10:45 -
11:00 -
11:15 -
11:30 -
11:45 - Lunch
12:30 -
12:45 -
01:00 -
01:15 -
01:30 -
LOCATION SET!!! LEEDERVILLE SKATE PARK
Address: Frame Ct, Leederville, WA, Australia
Map: http://maps.google.com.au/maps?f=q&sou...e=UTF8&z=17
PM me with a time slot you would like first in first served
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
