  • Replies 75
SHOOT CONTACT PAGES ARE UP!!!! (without any editing, the pics will b edited after they are chosen)
http://www.flickr.com/photos/mkphotographyperth
GO THERE AND CHOSE WHAT CAR IS YOURS THEN CLICK ON THE IMAGE THEN GO TO ALL SIZES THEN CHOSE THE ORIGINAL SIZE AND HAVE A LOOK THROUGH THE PICTURES.
IF YOU FIND IT HARD TO KNOW WHICH PICTURE LOOKS BEST BUT YOU WANT ONE THAT LOOKS LIKE A FEW, SELECT A RANGE AND I WILL LOOK AT THE ORIGINAL SIZES AND PICK THE BEST LOOKING ONE!!!
PM ME THE FILE NAME (FOUND UNDER EACH THUMBNAIL)
HOPE YOU HAD FUN!!!
ADD ME ON MSN IF YOU DO NOT UNDERSTAND OR YOU WANT TO TALK ABOUT A CERTAIN PIC ETC.
[email protected]
(contact sheets will be up till next sunday first to contact me, first to get pictures edited)
was good, the chicks bailed before i could get pics with just them and my car :blink: haha next time, cheers Rob
sorry about that man, got a bit confusing near the end because the models had to bail. but they have confirmed that they are willing to do another shoot with us coz they had so much fun will be taking bookings again soon :D
better pick a better time of the day to do it next time. Exposure is all wrong due to the harsh light which makes it hard for the tog.
The cars in the bg and reflections aren't good either...gotta setup a bit better and frame the shot. Use some remote fill flashes, the models and car weren't exposed right.
just giving some advice on photo taking not editing. you can probably edit like a guru in ps or lr but if you take the photo right at the start it' less time fiddling in software.
random cars or ppl in the bg and shadows on the models' faces with over exposed cars can mostly be recovered but why make it hard for ya :yes:
i can show u some examples if ya want?
random cars or ppl in the bg and shadows on the models' faces with over exposed cars can mostly be recovered but why make it hard for ya :D
this is true it was suppose to b overcast that day so didnt really plan for 100% blue skies lol we are going to do another one and will be more concious of what you have said thankyou
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
