Hey all, I bought some HKS 264 cams (2nd hand) for my rb25det and they arrived today. Now they came in their box's with original instructions etc. I have looked over both cams ten times and I cant find a HKS stamp ANYWHERE. This to me seems wierd for such a big branded camshaft to have nothing written on it. One camshaft has U2 stamped on it one has U3. Can anyone tell me if they had the same camshafts or how to tell if they are indeed aftermarked HKS cams??
Jamie
https://www.sau.com.au/forums/topic/263411-hks-camshafts/
  • Replies 44
i dont think any cams have their brand on them..
tomei hks etc etc all are unmarked
Oh really?? Ive seen some marked hks, and was just having a read of different forums of people with my same concern. As my stock camshafts are still in the car I have nothing to compare them with.... anyone know how im going to tell?
https://www.sau.com.au/forums/topic/263411-hks-camshafts/#findComment-4507664
Call the dude and ask him, atleast the HKS ones have markings so you know, with the Tomei ones they dont have shit, so you put them in hoping you have the right ones.
Here's a question for you, on the stock camhafts, near the cam gears, you can put a spanner on it. On the HKS ones you can do the same thing half way down, the stock ones have nothing. Do yours have these?
Edited by PM-R33
https://www.sau.com.au/forums/topic/263411-hks-camshafts/#findComment-4508007
Nope mine have nothing like that...its at the end where the cam gear is....and the part of the shaft in between the lobes (where your hks is printed) is concaved on one side all the way down....whereas yours looks solid
https://www.sau.com.au/forums/topic/263411-hks-camshafts/#findComment-4508024
Hmm interesting, the stock ones have the concave....
https://www.sau.com.au/forums/topic/263411-hks-camshafts/#findComment-4508049
The HKS cams I had did not have HKS stamped on them and now my TOMEI cams also don;t have any branding stamped on them.
Ahhhh you serious? Did they have the concaved bit between the lobes?? (like in my pic) What car were they for??
https://www.sau.com.au/forums/topic/263411-hks-camshafts/#findComment-4508100
Ive just searched two different forums and they both said Genuine HKS cams will have HKS stamped on them. Who can confirm this? Im pretty sure theyd have something on them being such a massive Brand. One camshaft should say HKS and one should say 264 apparently.
https://www.sau.com.au/forums/topic/263411-hks-camshafts/#findComment-4508192
    • So I'm going to have to keep ignoring the 4.7 update, or whatever version it is? Poop. I was hoping you'd put me out of my misery.
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
