Hey everyone of SAUQLD!
wasn't sure where to put this,
Anyway, Im coming to brisbane for a holiday over easter (fly in on the 8th)
just wanted to know what everyone would recommend doing while over there
not really into the touristy type things
I wanna see the good pubs/clubs
find out if there's any motor sport events happening anywhere between the 8th to the 15th?
that sort of thing
I'm going to be staying with a friend who lives in Casteldine
good area? all i know is that its about half an hour north of brisbane :down:
Cheers :bunny:
Karl
https://www.sau.com.au/forums/topic/263467-coming-to-brisbane/
there's some nissan datsun club annual thing goin on apparently.
funny thing about brisbane is that if there's a long weekend everyone pisses off and goes to the coast or somewhere that's not brisbane.
only feature in carseldine is an abandoned university and a BP... :)..
you'll be close to the train so jsut jump on - burn into the city (about 25minutes) - and go check out whatever. Then u can get trashed and sober up on public transport - yay - such fun :P
well i arrived yesterday and spotted about 20 skylines on the way home from the airport
(one really nice purple dewinged 32)
heaps of 180s and other imports driving around as well, got a few weird looks when they revieved thumbs up or waves from a guy driving a rentral Aurion haha
also found out you guys have a Toll when going over the bridge (sucked in :D )
went to Movie world, plan to go to dream world one of the days.
crazy how it will poor with rain for about 2 minutes then everything is fine again
figure this would be good enough spot to put post in.
coming to surfers on monday
whats the average/rough price of taxi from gold coast airport to cavill ave
just wanna work out whether its cheaper then the $75 each way for me n the missus.
cheers
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
