  • Replies 494
Posted Images
sounds good i ll see wat happens.
i want this whole topic thing to be used for and by gold coasters like if u spot someone or u wanna plan something. or just wanna tell a story so yeh people feel free to write whateverr.
well my old man is a retired mech so what i cant do i hit him up for. Brendan said eairlier that he is a 3rd year mech workin at a shop he has with his old man.
Gavin wood in labrador are also well spoken about.
For tuning id go to spry
yeah we have a workshop down in southport, 2/78 davenport street called M&S Auto Repairs. we do a fair bit or work on imports and any other sorta cars. servicing, tune ups, clutches, brakes, engine work, auto to manual conversions and any ohter sorta mechanical needs. we are willing to help out members to this site so feel free to call us on 5531001 for quotes. we also do roadworthy certificates.
cheers
Brendan
CRUISE IS SET TO 7TH OF JUNE (due to coz i didnt realise there was another thing happenign on the same day)
More infomation is in the Events section under EOI for a cruise
see ya there!
Brendan
Edited by 13rendan_88
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
