  • Replies 494
Posted Images
all good man im in robina will hav to meet at sum stage :)
Ah k well im in Miami so thats close as.
I will be home from work on monday arvo and got the whole week off so ill post up here when im back an wel think of somewhere to meet up :bunny:
I will be home from work on monday arvo and got the whole week off so ill post up here when im back an wel think of somewhere to meet up :ninja:
sweet as get my car back 2moro!
whos out 2 night????????????
Hey Dan didnt end up gettin the car back due to a few changes being made and some other stuff being added.
I will def organise something when I get it back next week ;)
Oh yeah hows your car now with the conversion you got done?
man its like a new car so much faster mor fun now its 2wd. Cant w8 to go out ther all ways bout 10 cars that go past me house on a saterday night bout 10:30 a real mix of cars to. im going to follow them next week lol ;)
what you having done mate ??
man its like a new car so much faster mor fun now its 2wd. Cant w8 to go out ther all ways bout 10 cars that go past me house on a saterday night bout 10:30 a real mix of cars to. im going to follow them next week lol :)
Hahah sounds good.
Im getting Garret gt3582r, 6boost highmount manifold, custom catch can, custom fuel rail, seimens 700cc injectors, turbosmart fuel reg, extrenal fuel pump, custom intake, intake manifold painted, rocker covers painted, custom 3 1/2" dump, adjustable camber arms, ksport coilovers and alot of little hoses changes and things polished to make it look all pretty :)
I think thats about it ;)
My avatar is a progress pic of my engine bay.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
