As stated,
Its time to offload some parts filling up the garage.
Firstly its time to let go if these beautiful rims. They are BBS LM 18 x 10 +20 in perfect condition besides one small gutter rash about 2cm long. Besides this they are like brand new. Dont pay $2000 per rim as charged by the Aust distributor. Fits R32/R33/R34 GTR
Rims only:$2500
Secondly, Greddy E-manage Ultimate with harness for R32 GTR with receipts from CRD. Was making 285kw atw and drove beautifully. Selling due to new tuner prefering PFC.
$700
Finally, brand new Catco 3" High Flow Metal Race Cat. - Stainless
Vehicle Compatibility: - R32/33/34 GTR - S13- R32 GTS-T - R33 GTS-T - Cefiro A31 - Laurel C33 - Stagea WGNC34- 300ZX Z32 - Pulsar GTI-R
- 3" Flanged
- Flows 706.2 CFM
- 200 Cell
- Gaskets Included
$400. Sells for $440 through Justjap.
All parts located in Sydney. Willing to ship interstate.
cheers
MAtt
0423885535
Edited by mattblack
hi, im a regular on the skyline owners club in the uk, im interested in your emanage ultimate and harness :blink: would you be able to post over to the uk with it labeled as a gift :) ?? and would you take 600$ plus postage ?? :D thanks
alex
