Hi guys,
Im selling the centre console from an r34 gt-t, with a popup one screen. This unit can apperently can run cd/dvd/any aux output and has the ability for sat-nav. I bought this item off another forum memeber, but didnt realise that since mine is a r34n/a model there is nowhere for the screen to bolt into... yeh kind of a major oversight lol. It has never been installed and has been sitting at my desk so i figured someone will have more use for it than me. Its located in Perth but willing to post, paid 300 looking for around 250 ono. As i sayd it includes the a/c unit, the deck for the screen, the screen itself and a cover for the screen.
Cheers
ash
https://www.sau.com.au/forums/topic/263684-r34-centre-console/
I would normally not bother commenting but will say this to ensure no-one gets misled - there is considerable misinformation in above posts about what the Xanavi can do and what it takes (loom, aerials etc tec) to instal one in a non-factory std Xanavi R34 (let alone a R32 or R33) and get it to function - maybe seller etc is well intentioned and erroneously believes what is stated is correct - but any potential buyer better do his research thoroughly or you probably end up with some expensive useless items- nuff said
"just need the right wires to power it up and a dvd player" - actually, on the scale of easy projects it might be easier to try brain surgery on yourself with a power drill - lol - :)
"just need the right wires to power it up and a dvd player" - actually, on the scale of easy projects it might be easier to try brain surgery on yourself with a power drill - lol - :sick:
wow, did you feel your dick grown bigger after you said that? your awesome
Edited by viet_boi
LOL at john!
Anyways people do your research, i don't know much about all this stuff just what ive been told. No its never been fitted by me because my dash is different to the gt-t... nowhere for this stuff to bolt into. Bought it off john who commented above. Cheap replacement screen for anyone with this existing setup.
lol don't worry about him, i'm pretty sure everyone on SAU knows that KV2R34GT is just a worthless troll
as for the sale, it's up to people to do their own research before buying the item
________________________________________________________________________________
_____________
Hey Tharaka dude, you are on the Vic Exec Ctee according to your sig so you must no its SAU policy not to permit gratuitous personal attacks - but hey maybe the rules don't apply to you - are you exempt ? Can you please explain?
And then you went on and validate my input in your last line comments.....isn't that being a bit of hypocrite on your part- to criticise me for my input then validate it?
lol- geez I had a good laugh though.
As the (former) great Jeff Fenech would say , ".......luv youse all.........."
lol
Call the wambulance someones going to get hurt.
nah .... were all distantly related (like about 5 million years ago) so its all cool
he's a great bloke , sometimes funny too!
[/color]
guess every car club has its own Muppet, guess we found it now.
stop posting already and let the guy sell his item.
as Chuck Norris would say.. "Shut the f*k up or get the f*k out"
Edited by viet_boi
can you post pics of the rear of the screen??? what are the inputs?
i have a 7" motorised screen in excellent condition no dead pixel or scratch only used twice. would you be interested in a swap??? ill pay for postage for both item?
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
