pic qualities are not the best because my lens is cracked but at least we can still see it. the GTR came from Victoria as a demonstration model where the GTR mechanics were trained to drive them...
post-54418-1238580211_thumb.jpg tyres after 4000km and they cost 1500 per wheel
https://www.sau.com.au/forums/topic/263804-gtr-gtr/
some more pictures not necessary bigger but clearer this time. had to destroy my plastic surround to clear my lens
if you collect issues of MOTOR magazine, this is the car thats featured in there;check the plates, plus its only 2 seconds slower than a V8-so called- supercar around a track(not joking). the cars actually shipped here not driven. its a demonstration model so its been used to train people to drive them in Victoria, which explains the tyre wear
the cars getting unveiled at the showroom tonight. it will remain there tomorrow so anyone can have a look.
Edited by R33_NICK
https://www.sau.com.au/forums/topic/263804-gtr-gtr/#findComment-4514727
think this might be the one a mate and i saw at the ravo ( ravenswood hotel) last sunday very nice tho i still prefer the more agressive look of the 32/33's
*even if i did cream my pants over it*
Edited by GWP021
https://www.sau.com.au/forums/topic/263804-gtr-gtr/#findComment-4517066
One of the electrical engineers here at work was just bragging about taking it for a test drive on Friday night.. not a shitty 5min round the block test drive like all the purchasers though.. he got to take it out the back of gnangara and have some fun.. BASTARD! lol
https://www.sau.com.au/forums/topic/263804-gtr-gtr/#findComment-4520314
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
