Hi all,
Well i just went out side to move the stag to the shed to fit the SITC.
Start car ran rough then died started it again and it ran rough then died, start thinking WTF?
Check fuel gauge and its well below E.... dont remeber driving it till it was bone dry but hay its happened haha
Is their anytrhing i need to do once i go get a 10L jerry and fill it up before i start it? or just turn ignition on and let fuel pump run till i hear it cut out then crank it?
cheers
https://www.sau.com.au/forums/topic/264379-im-an-idiot/
i fully dont rember it being that low ?
BP is at the end of the road that my road runs off.... its all downhill its just my car is facing the other way and its to narrow for u turn...
tried to get it rolling before but its soooo f**king heaving and no P/S sucks
https://www.sau.com.au/forums/topic/264379-im-an-idiot/#findComment-4520332
Nothing to worry about skyline fuel pump has a nice sock on it so shouldn't drag rubbish up either
nick there is plenty of leeway between fuel light and empty my manual says there is 9ltr in the tank when the light comes on thats almost 100kms
i did the same at lukes house once due to parking on incline :nyaanyaa:
https://www.sau.com.au/forums/topic/264379-im-an-idiot/#findComment-4520375
Its better then what my sister did!
She was driving me to school in her old 4cyl VH commodore (HAHA it was the funnist car, brown, stockies etc) when in the middle of an intersection at Golden Grove it ran out. She left me in the car while she walked home to get mum (had no credit on phone).
I was 14 in school uniform stuck in an intersection and RAA drive past and offered to tow me out of the intersection so I jumped in the drivers seat and got towed while everyone walking to school stood watch. Good times.
https://www.sau.com.au/forums/topic/264379-im-an-idiot/#findComment-4520430
Im well aware what a lawnmower runs on just saying your willing to put that shit in why not chuck 2stroke in also
Cos your cars never had 91 through it then.....? this is the first time mine has had it. and at the most it was 1 L WOW!
https://www.sau.com.au/forums/topic/264379-im-an-idiot/#findComment-4520460
lol I remember picking my RX-2 up from the workshop with an extra 100bhp over when it went in, the problem was that it drank accordingly. I picked my new GF up for our first date, and the thing ran out as I was turning right on North East Road! Thankfully I was heading downhill, and there was a servo on the corner, so there I was pushing the thing across the intersection, with the GF refusing to get out the car and help lol. I should point out that GF is now the mother of my 3 kids :nyaanyaa:
https://www.sau.com.au/forums/topic/264379-im-an-idiot/#findComment-4520553
priorities, set the precedence early.
https://www.sau.com.au/forums/topic/264379-im-an-idiot/#findComment-4520579
Ok got a 10L jerry and the gauge just moved haha....
Got it in the shed, wired in SITC.
Drove to BP filled it up went for a quick drive to warm it up.
Go home check base timing with light. Bang on 15 deg. Wind in 5 deg advance on 800rpm on the SITC check timing and suprise theirs 20deg advaced. wind it 5 deg retard and their we have 10 deg advanced... So its all working :D sweeett
Now am going to source and fit a 3" dump/front pipe and get it to boostwerx for a SAFCII and SITC tune
https://www.sau.com.au/forums/topic/264379-im-an-idiot/#findComment-4521115
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
