Hi all,
Well i just went out side to move the stag to the shed to fit the SITC.
Start car ran rough then died started it again and it ran rough then died, start thinking WTF?
Check fuel gauge and its well below E.... dont remeber driving it till it was bone dry but hay its happened haha
Is their anytrhing i need to do once i go get a 10L jerry and fill it up before i start it? or just turn ignition on and let fuel pump run till i hear it cut out then crank it?
cheers
https://www.sau.com.au/forums/topic/264379-im-an-idiot/
i fully dont rember it being that low ?
BP is at the end of the road that my road runs off.... its all downhill its just my car is facing the other way and its to narrow for u turn...
tried to get it rolling before but its soooo f**king heaving and no P/S sucks
https://www.sau.com.au/forums/topic/264379-im-an-idiot/#findComment-4520332
Nothing to worry about skyline fuel pump has a nice sock on it so shouldn't drag rubbish up either
nick there is plenty of leeway between fuel light and empty my manual says there is 9ltr in the tank when the light comes on thats almost 100kms
i did the same at lukes house once due to parking on incline :nyaanyaa:
https://www.sau.com.au/forums/topic/264379-im-an-idiot/#findComment-4520375
Its better then what my sister did!
She was driving me to school in her old 4cyl VH commodore (HAHA it was the funnist car, brown, stockies etc) when in the middle of an intersection at Golden Grove it ran out. She left me in the car while she walked home to get mum (had no credit on phone).
I was 14 in school uniform stuck in an intersection and RAA drive past and offered to tow me out of the intersection so I jumped in the drivers seat and got towed while everyone walking to school stood watch. Good times.
https://www.sau.com.au/forums/topic/264379-im-an-idiot/#findComment-4520430
Im well aware what a lawnmower runs on just saying your willing to put that shit in why not chuck 2stroke in also
Cos your cars never had 91 through it then.....? this is the first time mine has had it. and at the most it was 1 L WOW!
https://www.sau.com.au/forums/topic/264379-im-an-idiot/#findComment-4520460
lol I remember picking my RX-2 up from the workshop with an extra 100bhp over when it went in, the problem was that it drank accordingly. I picked my new GF up for our first date, and the thing ran out as I was turning right on North East Road! Thankfully I was heading downhill, and there was a servo on the corner, so there I was pushing the thing across the intersection, with the GF refusing to get out the car and help lol. I should point out that GF is now the mother of my 3 kids :nyaanyaa:
https://www.sau.com.au/forums/topic/264379-im-an-idiot/#findComment-4520553
priorities, set the precedence early.
https://www.sau.com.au/forums/topic/264379-im-an-idiot/#findComment-4520579
Ok got a 10L jerry and the gauge just moved haha....
Got it in the shed, wired in SITC.
Drove to BP filled it up went for a quick drive to warm it up.
Go home check base timing with light. Bang on 15 deg. Wind in 5 deg advance on 800rpm on the SITC check timing and suprise theirs 20deg advaced. wind it 5 deg retard and their we have 10 deg advanced... So its all working :D sweeett
Now am going to source and fit a 3" dump/front pipe and get it to boostwerx for a SAFCII and SITC tune
https://www.sau.com.au/forums/topic/264379-im-an-idiot/#findComment-4521115
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
    • Well, yeah. But I just expect everything other than my car to feel like a bucket of shit anyway. I still miss my Alfa 116 so much though. You could run over a 20c piece and tell whether it was heads or tails.
