hey guys i have an r32 with a rb25de motor and i have a spare rb20det turbo
was wondering how the turbo would cope with the rb25de motor?
im guessing it would be spooling up alot faster compared to a rb25 turbo
im not looking at running much boost as i want to keep my motor alive, ive heard when u turbo a non-turbo motor the most boost u should run is 8-9psi
depending how the turbo goes i might run half that as wouldnt running the smaller turbo on a bigger motor hurt the turbo?? or would it just max out earlier, im guessing i would have lots of low down torque when the turbo spools up then it would probs max out buy 4000rpm
any turbo experts like to shed some light on this??
https://www.sau.com.au/forums/topic/264542-rb20-turbo-onto-r32-rb25de/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
