Firstly i thought i would share a bit of history of the car
**these first pics are from a previous owners posts on another forum**
here she is b4 it all started
the guy, then shaved off the rear door handles, and the gay airvent
then it was given a budget respray
after this the guy put in in the 4k and strapped a 2nd hand t28 turbs on there
this is the previous owners finished project
when i bought it, it had a newer turbo on, and some ass hat had put the stock carby back on. here are some pics of it pretty much as it was when i picked it up
the fuel tank was pissing fuel out of it (would drain 45lt over night) and the carby was dropping fuel straight onto the exhaust housing of the turbo :)
the other thing i have done is get some TRX wheels on the old girl... had nightmares with wheelnuts
needs a wash, but u get the picture :down:
i tried to mend the tank with a stick welder (the big weld was already on there.. i just made the hole lol)
also the plenum for the carby is being modified, the inlet needs to me facing toward the turbo so i can use the same pipe between the carb and turbo
needs to face the front of the car, and not across the rocker cover
i got a hookup with an ex-hot rod builder who was willing to take an oxy torch to the tank and fix the plenum
here is the fixed plenum:
and the tank now has massive weld on it (previously just had a dirty big one) :sick:
it still leaks the tiniest bit, but i will fix that with putty. due to the way the fuel system is set up (no return line so that fuel runs thru the exhaust into the turbo to give me a bit moar power) it pressureises the tank to 9psi making the leak seem bigger than it is.
here is a mock up of the induction pipe and plenum :
and here she is all plumbed up. i had to do alot of sketchy grinding on the induction pipe to fit well... didnt have anything to hold it so i had a well rickety rig holding it together
please note the use of cable ties to keep the throttle cable in place, and my ghetto bracket to keep the fuel line off the rocker cover lol
also my kick ass oil breather (11ty extra kw right there).
need to play with plug gaps and timing to get her running... it will go without the turbo plumbed in (although not very well atm) and stalls with it all together.
more updates as the come :)
https://www.sau.com.au/forums/topic/264718-my-rolla/
  • Replies 45
lol vu, abusing the like on SAU :sick:
got fuel delivery issues too... will need a better pump and im gonna put an adjustable fuel reg in there too.
no doubt once i come to villis to show it off the gearbox or diff will go pop (they are pretty damn tired).
im just working on it slowly to spite u dave :)
https://www.sau.com.au/forums/topic/264718-my-rolla/#findComment-4524614
looks like such a cool little project to work on this 4K-turbs, nice work Carl! is this Ryans old car?
im thinking about buying another rolla, will probably be looking out for a cheap KE70 in the future. i've still got 4k parts & goodies to suit in my shed!
https://www.sau.com.au/forums/topic/264718-my-rolla/#findComment-4524630
yeah ryan had it for a short while... he got frustrated with it and kicked the shit outta the passenger side quarter panel lol
dont make me come over there, drink all your beer and call you lazy!
awesome motivation... do you live in a van by the river?
Almost the same colour as my old 200B ... which I threw in an SR20DE and supercharged it! :)
awesome!, one day i might throw a better motor in, but atm im a bit adverse to spending much $$ on it cos i got it pretty damn cheap. dont want it to owe me as much as the 32
https://www.sau.com.au/forums/topic/264718-my-rolla/#findComment-4524672
cheers guys, im surprised at the rolla love on here ;).
will be a good lil daily once its complete.
i have a spare gearbox in the shed, and on the lookout for a diff that is ok (might weld the one that is in there for when i wanna have fun).
a mate of a mate has started a white walling company, and since its not a VN commodore i reckon it will look good :)
https://www.sau.com.au/forums/topic/264718-my-rolla/#findComment-4524993
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
