List of attendies updated
PBK1776
Shane666
Jeffworld2
FIGJAM
R2THEJ
MICOR
GIZZMO
APHRODITE
PINKCESS
RADZ
TKR
SLY-25T
PELAO
punisher6942
BigAmph
NYTSKY
Dave
Bloody hope my cars on the rd for this:) big probs with AFM. anyone here have one like NOW??????
I got 2 x standard R32 GTR AFM's for sale... I'm in thr liverpool area...
  • Replies 93
Posted Images
Thanks guys:) One is being put in tonight, hopefully it solves the prob:)
Ok re cruise. Please state where you are going to meet... I am not sure if ppl are going to come to the granville maccas so i dont want to be the only one just sitting round waiting:) :blink:
So please please let me know whethr u meeting at crossroads or granville.
Remember that the Granville meet is Maccas on corner of merrylands rd and woodville rd. Then we cruise down to the Crossroads meeting up with the rest opf you in car park out front of KFC.
Thanks
really really hoping my car is bk on road :D
If not, dave im coming with you:0
Yey!!!!!!!!!!!! My car is back!!!!!!!!!!!! :P
Soooo, unless someone posts that they will be meeting at granville, i will not go there i dont think cuase its out of my way to be sitting there for ages and have noone show up there.
So ppllllsssss post if you have nay intentions of meeting aT GRANVILLE maccas by 8.30 am tom or ill just head straight to crossroads.
http://203.84.234.232/amfphp/main/retail.php?m=16&s=F2
Follow this link to get to the location of KFC at crossroads
http://www.crossroadshomemaker.com.au/howtogethere.amx
follow this link to get to crossroads
Below is one possible route we can take
Camden Valley Way & Beech RdCasula New South Wales 2170, Australia
1. Head south on Beech Rd toward Parkers Farm Pl
Go through 1 roundabout 0.7 km
2. At the roundabout, take the 1st exit and stay on Beech Rd 0.2 km
3. Turn right at Campbelltown Rd 13 m
4. Take the ramp onto South Western Fwy 36.5 km
5. Take the exit toward Picton Rd 0.7 km
6. Turn left at Picton Rd 6.4 km
7. Slight left at Mount Keira Rd 17.3 km
8. Continue on The Link Road 3.7 km
9. Take the ramp onto Southern Fwy 23.2 km
10. Continue on Princes Hwy 2.4 km
11. Slight right to stay on Princes Hwy 88 m
12. At the roundabout, take the 2nd exit onto Illawarra Hwy
Go through 1 roundabout 14.5 km
13. Turn left at Clover Hill Rd 0.6 km
Macquarie Pass New South Wales, Australia
I have printed this out a few times so ya'll can have one:)
ill be at crossroads.... my attendance on the actual cruise will depend totally on how wet it is also and having no stereo hooked up in the car leaving me with no music to keep me amused is incentive to not go for a long drive lolz but i will definitely stop in at the crossroads for a visit and to say hi to everyone
GUUYYYYSSSSS!!!! A bit if rain never hurt anyone!! See you at all the crossroads at 11.20am. I will prob be there a bit earlier. Newbys just look out for my black 33 with pink calipers and pink interior:)
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
