Heya,
Am thinking bout rebuilding my engine but the quotes ive been given this week are ridiculous, so im thinking of building up my own rb30 bit by bit and eventually drop it in the car.
What i want to know is who here has done it and can give me some guidance if i require it? I've researched it a bit (not enough to go and do it right away) but want to know if you guys have had any specific issues with it? Only chasing 250-300kw and have heard of people doing it on stock bottom ends, how safe is this? What are some places people had experience with machining etc. if i want to rebuild it with fogies etc.
My goal is to have a responsive and reliable motor for track and hill climb, therefore power is not the biggest issue.
Budget $2,500 - $3,000
(ps, its in SA section because i want to get local opinions and answers)
https://www.sau.com.au/forums/topic/265024-rb30-conversion/
  • Replies 49
Heya,
ummmmmmmmmmm.........u wont get 1 built that cheap, you will need atleast double or triple that
contact nisspeed or lewis engines
its not as easy as u think, theres a lot things u need to factor in
https://www.sau.com.au/forums/topic/265024-rb30-conversion/#findComment-4528100
http://users.tpg.com.au/cobra30/twincam.htm
http://www.ripsltd.com/index2.html
RB30 Stock internal bottom ends start at NZD$4,000 rwd or $5,000 4wd (suit up to 600hp and 7200 rpm)
$4000nzd = 3,243.59 AUD and shipping fron NZ is about 400-450
EDIT
http://www.skylinesaustralia.com/forums/R3...ion-t15420.html
bottom of first post has a download
https://www.sau.com.au/forums/topic/265024-rb30-conversion/#findComment-4528106
as steve said above then add on installation, tuning, etc etc.........................
goodluck
https://www.sau.com.au/forums/topic/265024-rb30-conversion/#findComment-4528114
at least with rips put your money into the main part a short motor and use your gear to get it up and running if your mechanically minded and have a daily then it shouldn't be too hard to follow online manuals there are plenty about
EDIT
Son an RB30DET would be a responsive motor with the right turbo
https://www.sau.com.au/forums/topic/265024-rb30-conversion/#findComment-4528117
key to me spending 2.5-3k is I'm doing it myself. i know that obviously no one is gonna build me one that cheap, there's a lot of labor in it.
I'm not a complete idiot when it comes to this either, I've had experience in rebuilding a volvo turbo motor as well as a rubbish vt ecotec through tafe so have a pretty good idea of how things are done.
Thanks heaps for the links steve, got a bit of reading to do eh?
Reason why do it with an rb30?
1. torque
2. bigger displacement is always a good thing
3. matched with the right turbo and set up properly it would give me better results than doing the same with an rb25
4. rebuilding my motor (rb25) myself would cost roughly the same
5. id rather have my car running as long as it can while i build a motor for it
https://www.sau.com.au/forums/topic/265024-rb30-conversion/#findComment-4528133
AFAIK his 240Z engine still runs the standard block, crank and crank girdle. So no it's not the 20K version as that engine has an aftermarket full crank girdle with billet main caps.
TX3 i still don't think you are going to be able to do it for 2.5>3K. Pistons and rods you'd be looking at nearly 2K (if your going to do it properly) having said that the i think SPOOL do a piston and rod kit for around the $1400 mark for an RB30 bottom end. machining and balancing (balancing need to be 110% with a long stroke engine like an RB30) you'd be looking at another $3-500 ARP studs for mains and head studs $2-300 full gasket kit $300, decent turbo like a GT3071 or 76R your looking at $1700-2200 etc, etc. and these are just parts
EDIT!! No i was wrong about the spool package it's $2190 not $1400 (thats more like the CA price)
http://www.spoolimports.com/content/SPOOLC...TONPACAKGES.asp
Edited by D_Stirls
https://www.sau.com.au/forums/topic/265024-rb30-conversion/#findComment-4528136
you're choice but if you shop around you'll find that it's cheaper than you think to rebuild the rb25! jjr selling autech rods are around $700-800 mark and cp pistons from jjr $1200 and these are just examples so you do the maths if it'll be roughly the same price!
on another note when running rb30 bottom and rb25 head does it get bored out? and by how much?
https://www.sau.com.au/forums/topic/265024-rb30-conversion/#findComment-4528141
1. torque
you should buy a blown engine n build that 1 up, that way u can stiil drive your car until its built, and if u get defected u can drop your old engine back in
ive got the perfect turbo for it sitting at home, a garrett gt30/40 with .82 external gate exhausting housing, cubes uses the same turb on his rb25/30 i think but is interl gate
https://www.sau.com.au/forums/topic/265024-rb30-conversion/#findComment-4528146
No 25, 26 and 30 bores are all 86mm so there is no boring required unless you are using a 20 head. With the 25 head you have to do something about the oil feed for the VTC but there are a few solutions if you look around.
When i build mine i'll be using a 26 head as it is already solid and you don't have to play around with any oil galleries (apart from what you already have to do in the 26's i.e. restrictors and such) i will be retapping the block to take the bigger head studs that the 26 uses but there is some debate about doing this.
P.S. i though cubes used a GT3071R??
Edited by D_Stirls
https://www.sau.com.au/forums/topic/265024-rb30-conversion/#findComment-4528155
so nothing to do with displacement? just longer strokes is where the extra torque comes from?
Edited by nos man
https://www.sau.com.au/forums/topic/265024-rb30-conversion/#findComment-4528161
Dan the guy wants to do hill climbs and not powerslide off cliffs with your turbo!
haha too right... not after lag than instant smoke show.
i have thought about this also, well still thinking about all this stuff, hence why i made a thread to see who has actually done it in SA. Anyone keen to take me for a short spin :D? Really keen to find out what the response and driveability are like.
Edited by tx3_90
https://www.sau.com.au/forums/topic/265024-rb30-conversion/#findComment-4528167
longer stroke also = more displacement......even if you don't touch the bores.
seriously though, unless you have access to internal & external micrometers, plasti-gauge, torque wrenches, etc or understand the importance of sequences, preparation for initial fire up and absolute cleanliness.......don't even think about assembling your own motor.
https://www.sau.com.au/forums/topic/265024-rb30-conversion/#findComment-4528225
    • WhatsApp+35796370243 Email: [email protected] Telegram: @tesgkm Vásárolj hamis pénzt, és segíts az embereknek szerte a világon elérni céljukat, hogy jó életet élhessenek, és megengedhessék maguknak azt, amit soha nem engedhetnének meg maguknak. Az én pénzemmel. Megvan. Valóra váltom az álmaidat, a világot eléd tárom, a közeli barátaid tisztelnek, az ellenségeid tisztelnek, és a legjobb életet biztosítom neked és a családodnak. hamis euróbankjegyek vásárlása hamis bankjegyek vásárlása Hol lehet hamis pénzt vásárolni? Hol lehet hamis játékpénzt vásárolni? Hol lehet hamis pénzt vásárolni? Valódi kinézetű hamis euróbankjegyek Eladó valódi euróbankjegyek hamis pénz vásárlása online észlelhetetlen hamis pénz vásárlása online hamis pénz vásárlása online az USA-ban valódi hamis pénz vásárlása online hamis pénz vásárlása online hamis golyók vásárlása hol lehet hamis bankjegyeket vásárolni hamis bankjegyek vásárlása online hol lehet hamis 100 dolláros bankjegyet vásárolni hol lehet hamis dollárbankjegyeket vásárolni hol lehet hamis millió dolláros bankjegyeket vásárolni hamis euróbankjegyek vásárlása hamis dollárbankjegyek vásárlása hogyan lehet hamis pénzt szerezni? hamis 20 dolláros bankjegyek hamis bankjegyek ellenőrzése Egy kényelmes otthon nagymértékben javíthatja az életminőséget. A pénz lehetővé teszi, hogy biztonságos, védett és kényelmes lakóteret biztosítson magának és szeretteinek. Milyen jellemzők vagy szolgáltatások tennék álomotthonná a házat?
    • Whatsapp+35796370243 [email protected] Telegram.@tesgkm Buy Counterfeit money and Helping people around the world to achieve their goal to make them have a good life for them to afford what they can never afford With my kind of money. I have. I will make your dreams come true make the world ahead of you make your close friends respect you make your enemies respect you and give the best life for yourself and your family. buy counterfeit euro banknotes buy fake banknotes Where Can I Buy counterfeit money where can i buy fake play money where to buy counterfeit money Real looking counterfeit euro banknotes Real euro banknotes for sale buy counterfeit money online buy undetectable counterfeit money online buy counterfeit money online usa buy real counterfeit money online buy counterfeit money online buy fake balls where to buy counterfeit bills buy fake bills online where to buy fake 100 dollar bill where can i buy fake dollar bills where can i buy fake million dollar bills buy fake euro bills buy fake dollar bills how to get counterfeit money counterfeit 20 dollar bills checking for counterfeit bills Having a comfortable home can greatly improve quality of life. Money can provide the means to afford a safe, secure, and cozy living space for yourself and your loved ones. What features or amenities would make a house feel like a dream home to you?
    • Whatsapp+35796370243 [email protected] Telegram.@tesgkm Money plays a huge role in our lives.Buy counterfeit money. It's needed for basics like food, shelter, clothing, and healthcare. Beyond that, it provides opportunities for education, travel, and personal growth. Financial stability can reduce stress and give people the freedom to pursue their passions. However, it's also important to buy counterfeit money, remember that money  isn't everything, Buy Fake Bills. for relationships, health, and happiness are equally vital. How do you think people can strike a balance between making money and living a fulfilling life? buy counterfeit euro banknotes, buy fake banknotes , Where Can I Buy counterfeit money, where can i buy fake play money, where to buy counterfeit money, Real looking counterfeit euro banknotes, Real euro banknotes for sale, buy counterfeit money online, buy undetectable counterfeit money online, buy counterfeit money online usa, buy real counterfeit money online, buy counterfeit money online, buy fake balls, where to buy counterfeit bill, buy fake bills online, where to buy fake 100 dollar bill, where can i buy fake dollar bills, where can i buy fake million dollar bills, buy fake euro bills, buy fake dollar bills, how to get counterfeit money, counterfeit 20 dollar bills, checking for counterfeit bills, Buy undetectable counterfeit money, buy fake money that looks real online, where can i buy fake money that looks real, where can i get counterfeit money, Money is a necessity! People need it to cover basic expenses like food, shelter, and clothing, as well as for savings, investments, and achieving long-term goals. Financial stability can reduce stress and provide peace of mind. What's your take on financial planning or money management?
    • Whatsapp+35796370243 Email: [email protected] Telegram: @tesgkm Kupujte ponarejen denar in pomagajte ljudem po vsem svetu doseči svoj cilj, da si zagotovijo dobro življenje, da si lahko privoščijo tisto, česar si z mojim denarjem nikoli ne morejo privoščiti. Imam. Uresničil vam bom sanje, ustvaril svet pred vami, naj vas spoštujejo vaši bližnji prijatelji, naj vas spoštujejo vaši sovražniki, in zagotovil vam in vaši družini najboljše življenje. Kupiti ponarejene evrske bankovce Kupit ponarejene bankovce Kje lahko kupim ponarejen denar Kje lahko kupim ponarejen igralni denar Kje kupiti ponarejen denar Pravi ponarejeni evrski bankovci Pravi evrski bankovci naprodaj kupiti ponarejen denar na spletu kupiti nezaznaven ponarejen denar na spletu kupiti ponarejen denar na spletu ZDA kupiti pravi ponarejen denar na spletu kupiti ponarejen denar na spletu kupiti ponarejene kroglice kje kupiti ponarejene bankovce kupiti ponarejene bankovce na spletu kje kupiti ponarejen 100-dolarski bankovec kje lahko kupim ponarejene dolarske bankovce kje lahko kupim ponarejene milijonske dolarske bankovce kupiti ponarejene evrske bankovce kupiti ponarejene dolarske bankovce kako dobiti ponarejen denar ponarejeni 20-dolarski bankovci preverjanje ponarejenih bankovcev Udoben dom lahko močno izboljša kakovost življenja. Denar lahko zagotovi varen, zaščiten in prijeten življenjski prostor za vas in vaše ljubljene. Katere lastnosti ali ugodnosti bi vam hišo naredile kot sanjski dom?
    • Whatsapp +35796370243 Telegram.@tesgkm O dinheiro é uma necessidade! As pessoas precisam dele para cobrir despesas básicas como a alimentação, a habitação e o vestuário, bem como para comprar dinheiro falso para poupar, investir e alcançar objetivos a longo prazo. A estabilidade financeira pode reduzir o stress e proporcionar tranquilidade. O que pensa sobre planeamento financeiro ou gestão financeira? Compre notas falsas online. comprar notas de euro falsas comprar notas falsas Onde posso comprar dinheiro falso? Onde posso comprar dinheiro falso falso? Onde comprar dinheiro falso? Notas de euro falsas com aspeto real Notas de euro reais à venda comprar dinheiro falso online comprar dinheiro falso indetetável online comprar dinheiro falso online EUA comprar dinheiro falso real online comprar dinheiro falso online comprar dinheiro falso online comprar bolas falsas onde comprar nota falsa comprar notas falsas online onde comprar nota falsa de 100 dólares onde posso comprar notas falsas de um dólar? onde posso comprar notas falsas de um milhão de dólares? comprar notas de euro falsas comprar notas falsas de um dólar como obter dinheiro falso? notas falsas de 20 dólares verificando se existem notas falsas A crise atual é realmente difícil, com muitas empresas e negócios a fechar, deixando as pessoas com dificuldades em sobreviver. É um verdadeiro desafio cuidar das famílias e pagar as contas quando as fontes de rendimento estão a diminuir. Que tipo de apoio ou recursos considera que seriam mais úteis para as pessoas afetadas?
