Hey Guys,
Just clearing out my garage and i happen to find some of my old suspension components which i had before i sold my car so lm just selling them cheap here! Pick up a bargain!
Brand new R33 Hicas Lock bar $80
Brand new Adjustable Upper Control Arm to suit S13 $160 RRP$300 from JustJap
Brand new Adjustable Upper Toe Rod to suit R32 $160
Brand new Adjustable Upper Control Arm R33 and S14 $150 *PENDING PAYMENT*
Brand new Adjustable Skyline Cam Gears $180 for the pair
Chinese Greddy Style intake Plenum $500
Brand new 52mm Racing Radiator to suit Mitsubishi Evo 7,8,9 $300 RRP$600
Brand new KKR430 Turbo $600 (need this one gone asap!) bought for $850 from Ottomoto
Brand new Universal Justjap Coolpro 30 row Oil Cooler $150 bought it for $200 (haven't used yet)
Brand new Universal Sandwich Plates $110 (will fit the oil cooler with a few fittings and hoses) bought it for $170 from just jap
Brand new Manual Boost Controller $40
All prices are negotiable and its first in best dressed.
Cheers
https://www.sau.com.au/forums/topic/265203-garage-sale-all-parts-must-go/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
