  • Replies 53
got any more 4 door 32 parts for sale?? how much for the skirts posted to nsw 2323?
I will measure them up and sent u a quote this weekend.... What other 4 door specific parts are u after??
  • 4 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
im also after 4 dr parts... wot do u have in terms of bodykit, suspension
4 dr side skirts are still for sale as are the Cusco castor rods, all the rest is gone..
  • 4 weeks later...
Still for sale
tubular bolt in 6 point roll cage with padding, plates, bolts. Came out of a D2 car from Japan, built for R32, not too sure what other cars it would fit into, possibly laurel/cefiro
$1000ono
R32 4 door type M side skirts, rare
$250pair ono
Genuine Cusco pillow ball castor rods/arms suit R32 gts/t S13
$250ono
Whiteline R32 front & rear strut braces, practically new
$320
R32 impul front sway bar with D-shackles & bushes
$100ono
R32 gtst manual standard computer, 93’ model, un chipped
$150ono
R32 type m front bar damaged on LHS,
$80 ono (pick up only)
Exedy Clutch Kit
This is a Heavy Duty Clutch Kit for the following:
Nissan Skyline RB20DET & RB25DET
R31- 1987-89 2.0Lt
R32- 1989 onwards 2.0Lt
R33- 1993 onwards 2.5 Lt
Purchased from CBA WA for $450
Clutch is practically new save $$
Clutch was used for approx. 2-3months on RB20DET powered Nissan skyline R32 with 210-220rwkw without slipping once. Very street-able clutch with good pedal feel (heavier than standard) and friction , clutch had a very easy life for the short period it was in my car (i don’t track or drift my car), data sheet that i have from when i bought the car says it has following specs:
clamping load = 2400 LB
faces = 2
Radius =7.625
Friction coefficient = 0.3
Torque = 457.6 ft/lb @ 4500 rpm
Horsepower = 392 HP
$250
RB20 clutch fans 1left
$40 each
Trust S15 exhaust and cat convertor. 2 parts held together with TRUST stainless clamp.
Has 'Jasma' plate on it (whatever that means)
Stainless rear cannon muffler (few scratches as seen in pictures but no dents)
Rest of exhaust and second muffler made from mild steel, painted in high temp matt paint.
Cat convertor is near new but is welded in place,
$700ono
Aluminium intercooler piping, lipped either end, 3” mandrel bent
$20 pair
R32 RB20 cam gears, standard parts, prefect condition, no wear on teeth, come as pair but may split
$50ono
R32 s13 front left lower control arm
$30
Nolathane ‘D’ shape bushes
Repco part no.
42150 (x2) 24mm ID/ 31mm OD
42937 (x2) 27mm ID /31mm OD
D shackles, for sway bar, tried to fit but never used, comes with grease sachet
$20
R32 ashtray with Apexi badge, rice up your interior with this fine specimen
hey looking for some rear suspension can u help me out for a R32?? cheerrsass
Sorry Jasmine, all the stuff that was for rear suspension has been sold. What exactly were u after?? Only have strut braces and bushes for a sway bar.
Cheers
Rob
  • 3 weeks later...
  • 4 weeks later...
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
