Hey Everyone just after a like a tally of how man r32 gtr owner out the want a front diffuser?A mate n i are gonna probly look at doin some of a few different designs.So if they turn out good we're thinkin bout sellin them to the public so u too can have a front diffuser becos i know im sick of noone wanting to get one in for us so how bout we sort something out n ill keep u posted once i see what sort of interest we get.I know either way ill be making one for my gtr so its up to u guys
https://www.sau.com.au/forums/topic/265657-expression-of-interest/
ok guys im gonna make one then post fotos n info up once i have something to work with.Also ill decide if there will be an under tray when i goin along n if there will be it will be a bolt on piece.Im more liking the idea of n extension of the lower lip but will see how i go
Any of u like the r34 nismo front diffuser?Cos i was thinkin bout doin that for a 32 as well if not just makin that n one that i custom make
Im in the process of making one for my R33 gts-t out of a f/g with sheetmetal base. Hard to find anything in stores. Definately interested in what you's come up with and the final dimensions to check for compatibility.
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
