Curmi Posted April 16, 2009 Share Posted April 16, 2009 1st question.....ok so my car drives normally then all of a sudden the car automatically revs the shit out of the car and hits 8rpm and doesn't stop so i pull over and turn the engine off and start again sometimes it starts normally other times revs to 5-6 by itself? wtf i blew my turbo last week and had plastic shit/little black pieces in the afm so cleaned it all out with air compressor and looked fine could my afm shit it self? this only happened after i blew the turbo. (and the afm was located on the intercooler piping now have changed it back to stock with a pod)...help please running fuel pump, fmic, pod, r32 turbo with hks actuator at 12 psi, full 3inch exhaust 2nd question......i had a remap computer mods were fuel pump, fmic, boost tee 13, pod, r33 turbo, full 3inch exhaust, now since i blew my r33 turbo and i put my r32 turbo back on can i still run the remap computer? i know its better to get a tune but dr drift was booked out and other places. and winton is this Sunday so need answers asap 3rd Question......i have a z32 afm can i unstall it with the remap computer and not have any problems (as in no need for a tune?) cheers guys Link to comment https://www.sau.com.au/forums/topic/265791-r32-rb20-questions-about-z32-remap-ecu-high-rev-situation/ Share on other sites More sharing options...
Flux_nz Posted April 16, 2009 Share Posted April 16, 2009 1st question.....ok so my car drives normally then all of a sudden the car automatically revs the shit out of the car and hits 8rpm and doesn't stop so i pull over and turn the engine off and start again sometimes it starts normally other times revs to 5-6 by itself? wtf i blew my turbo last week and had plastic shit/little black pieces in the afm so cleaned it all out with air compressor and looked fine could my afm shit it self? this only happened after i blew the turbo. (and the afm was located on the intercooler piping now have changed it back to stock with a pod)...help please running fuel pump, fmic, pod, r32 turbo with hks actuator at 12 psi, full 3inch exhaust 2nd question......i had a remap computer mods were fuel pump, fmic, boost tee 13, pod, r33 turbo, full 3inch exhaust, now since i blew my r33 turbo and i put my r32 turbo back on can i still run the remap computer? i know its better to get a tune but dr drift was booked out and other places. and winton is this Sunday so need answers asap 3rd Question......i have a z32 afm can i unstall it with the remap computer and not have any problems (as in no need for a tune?) cheers guys As the throttle is cable driven, one might assume it relates to that somehow, as with the throttle closed the engine wouldnt be able to rev to 8k. I'd check to see if the butterfly is sticking open or that the linkages are not tight. You can run the remap computer, but it might not run right, and might not be good for the engine. Best get it retuned. I doubt you can remove the z32 afm without a retune, it might run as per question 2, but it might be bad for the engine or not work at all Link to comment https://www.sau.com.au/forums/topic/265791-r32-rb20-questions-about-z32-remap-ecu-high-rev-situation/#findComment-4538979 Share on other sites More sharing options...
CEF11E Posted April 17, 2009 Share Posted April 17, 2009 you can run the car with the stock turbo and the remap suited for the r33 turbo but it will run rich. apart from that it will be fine. you can not remove the z32 and put the stock one back on. it would start but be un drivable Did I do the remap for you? cheers! Link to comment https://www.sau.com.au/forums/topic/265791-r32-rb20-questions-about-z32-remap-ecu-high-rev-situation/#findComment-4539515 Share on other sites More sharing options...
Curmi Posted April 17, 2009 Author Share Posted April 17, 2009 ok ill check those and with the z32 i have not instilled it on my car yet i want to put the z32 in now so will the car run fine with a remap and z32 not tuned??? Link to comment https://www.sau.com.au/forums/topic/265791-r32-rb20-questions-about-z32-remap-ecu-high-rev-situation/#findComment-4539827 Share on other sites More sharing options...
Dr_Drift Posted April 23, 2009 Share Posted April 23, 2009 You cannot change AFM/injectors without a tune Link to comment https://www.sau.com.au/forums/topic/265791-r32-rb20-questions-about-z32-remap-ecu-high-rev-situation/#findComment-4550837 Share on other sites More sharing options...
